Question about Fujitsu Siemens AMILO Pro V2010 Notebook
The key combination of the internet receicer doesn't work :S
The FN/F1 combination to my laptop doesn't work. dont know how but I cant connect to the internet.
  • Anonymous Mar 08, 2009
    cannot connect to wireless network cant find network switch on laptop
Installed a new launch manager and deleted the older.
Posted on Jan 28, 2009
Fn+num lk not working
There is no standard meaning to any Fn +Fx key combinations. It depends on the manufacturer and the laptop model.
Usually the Fn key works in combination with the Function (Fn) keys F1-F12, and maybe ESC.
In my Toshiba, there is an overlaid numeric pad that can be activated by pressing Fn +F11. Once the sequence is pressed the F11 key led remains lit, and the overlay active. Pressing the F11 key restores the normal keyboard. Fn+Num Lock does not do anything.
Please check you laptop's manual to familiarize yourself with the uses of the Fn key on YOUR computer.
Dec 19, 2013 | ASUS Eee PC 1000H Laptop
What is "FN" key
Most laptop keyboards have a key marked "FN" or "fn". This is just another shift key, like the shift, control, and alt keys. If the instructions say something like "Press fn+F1" then press and hold the fn key, press and release the F1 key, then release the fn key. Exactly the same type of procedure as when the instructions say something like "Press Control+P".
Mar 19, 2013 | Computers & Internet
I managed to lock my FN key and i dunno how to unlock it. Please help
Function Keys can be unlocked by using combination of Function (FN) key and any other key. Generally they are the F keys right on the top from F1 to F12.
Most often the following combinations work:
1) Fn + F6
2) Fn + Num Lock
3) Holding Fn for a while
4) Fn + F8
5) Ctrl + Fn
6) Shift + Fn
Please, all most at all times the function keys from F1 to F12 are marked and indicated about what they do. The marking is pointed by a small icon just under the name of the Function key.
Oct 24, 2012 | MSI Computers & Internet
I have spilled water on my laptot and the keyboard doesn't work anymore. I have connected an external keyboard now however, I cant switch on the wireless capability. Does anyone know a way to do t
There may be a switch on the side of the laptop that turns the wireless on and off. Also try pressing and holding the fn key and pressing and releasing f1 or f2. The water spill may have killed the wireless card also. If you still can't get it working, then purchase an inexpensive usb wireless adapter. This will plug into an available usb port and will give you wireles capabilities. You will need to replace the keyboard as well as it was obviously damaged by the spill. Check on ebay, or contact the manufacturer for a replacement.
Hope this helps!
Joe
Mar 25, 2012 | Fujitsu Siemens (AYU0N1090ED00103) PC...
The mouse pad is not working. Is there a way to turn it back on?
There's a keyboard combination to turn the touchpad on and off. It's usually the Fn key plus one of the F1-F12 keys. On mine it's Fn+F7 but that doesnt have to be the case with your laptop. Look over the F1-F12 keys and look for a rectangle logo. Dont mistake it for the toggle LCD-External Monitor key). Just try them out and see which one it is. If you mistakenly turn off your LCD just repeat the keystroke combination to turn it back on. This should be a straightforward try-fail thing. I once reinstalled everything on my old Toshiba because I mistakenly turned off the touchpad without even knowing I did so. :)
Jan 14, 2011 | Dell Inspiron M5030 Laptop
Presario v2000
Try this; Press Fn+F1 instead of F1 alone or Fn+\F2 not only F2. Most laptops are by default Fn key activated so we always need to press it with the key combination.
If this doesn't help, there must be internal faulty/problem. Boot up the system and keep pressing F8 and go into "Advanced Boot options", if it's working, then there's no hardware, must be the Fn key.
Good luck
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
How do you turn the wireless internet on and off on Acer 3810
There must be a small slide switch nearby the Wi-Fi led, or a keystroke combination with Fn key and one of the F keys (it must have the apropriate wi-fi symbol)
Stelios.
Feb 20, 2010 | Acer Aspire 3810 Notebook
FN+F1 no longer switches on internet, but restarts PC instead
You may have inadvertently reprogrammed the keys.
Look for utilities provided by the laptop manufacture (Programs) to configure the Fn-esse key combinations.
Hope it helps.
Sep 08, 2009 | Medion md40298 Notebook
Connecting my Logitech mouse
The Fn is key is normally next to the ctrl and alt key at the bottom left of your keyboard. The Fn key is a key..just like F1 F2, etc its just Fn..if you don't see the Fn key and you see a Windows key somtime that takes the place of the Fn key..Good Luck
Rate this solution with 4 diamonds before logging off.
Mar 22, 2009 | LG X-Note LM50 Notebook
Cant find the switch on my laptop to make me wireless
I can't find any info about that laptop on the internet. If you have xp, go to start menu, control panel, network connections and see if you have a wireless internet connection in there. If not, you do not have a wireless card in your laptop. If you do have that connection, right click to enable it.
Please rate, thanks!
Mar 16, 2009 | Evesham Voyager 5700 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
321 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
