Question about Dehumidifiers
Homehardware classic R410A - Dehumidifiers
I have a danby premiere r410 a, the compressor will not come on
Hi There,
I would love to help you, however I am not sure which model you have. R410A is not a Danby model number. The correct number can be found on the back of the unit as well as on the front cover of the owners manual. The numbers usually begin with "DDR"
Jun 28, 2012 | Danby Dehumidifiers
I NEED AN MANUAL
You may download a copy of the manual from here.
Jun 27, 2012 | Dehumidifiers
DANBY PREMIERE DEHUMIDIFIER R410A OWNERS MANUAL
I have 70 pint premiere dehumidifier , and it's not producing any water . What should I do ?
Jan 27, 2012 | Dehumidifiers
What is the proper setting for Danby R410A?
R410A is refrigerant gas. I think you wanted to know, what humidity extraction level the controls should be set on. If it is really hot and humid in your area, set the humidity extraction level between 35 & 40%. If you have a mechanical control, turn the knob to Maximum.
Hope this helped you, Bradleyjo. Thanks for choosing FixYa.
Aug 06, 2011 | Danby DDR4588EE Dehumidifier
My Danby R410A dehumidifier is not collecting any water. Are my settings wrong perhaps? Its humid here so it should collect something? Help!
The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the humidifier.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
Jul 10, 2011 | Danby Dehumidifiers
I have a DANBY PREMIERE R410A dehumidifier. I have misplaced the manual. I want to have the unit run for a fixed period of time (not all the time). HELP!!!
On the control panel the 3rd button from the left is the timer button. If you press this button when the unit is running the number display on the left will start blinking- use the up/down arrows to set the time that you want the unit to run.
If you press the timer button when the unit is off it will run on and off for the designated time you set- eg if you set 1 then every 1 hour the machine will switch on and run for 1 hour.
(The left # will just blink once you have the time you want just leave it and eventually the normal humidity setting reading will show)
Oct 18, 2010 | Danby Dehumidifiers
Dehumidifiers Logo
24 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
