Question about Sony RM-X153 Remote Control
How to open remote to replace batteries for Sony rm- ed035
  • 23 Answers
SOURCE: it is broken. I have sony integrated remote commander RM-AV3000 .Need codes
what is a mySTR-DE698? but more generic, like brand and what it does. TV or DVD etc...
Posted on Oct 15, 2008
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
  • 19 Answers
SOURCE: Code for Sony RM-V310A remote.
try going to and plug in the information there and see what you get
http://www.oneforall.co.uk/us_US/support
Posted on Aug 29, 2009
bahratt
  • 561 Answers
SOURCE: Sony remote rm-y135 got dropped into a bucket of
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the batteries.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put new batteries back in and power on.
Posted on Jan 14, 2010
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Posted on Jan 02, 2011
How do you Open Sony rm-yd059
SONY RM-YD059 remote is easier to disassemble then other models. Slide battery cover open 1 inch or half open. Using a plastic toothpick or similar device pop cover using the groove. There are three sliding locks on each side. You will now see six screws holding halves together - remove. There are six more clips holding remote together. Starting at the top working towards the bottom, there are three per side, location of clips at red and blue buttons, at between 4&7 and 6&9 rows, and finally at muting and jump buttons. Voila - Happy cleaning. Note: directional ring is keyed with thin and fat tabs, fat tabs are positioned towards the bottom.
Feb 04, 2013 | Sony RM-YD059 Remote Control 148947911
Fix Sony tv remote RM-ED035
Check this link to download the manual
Jan 19, 2013 | Televison & Video
How do you replace batteries in a sony rm-sp350 remote
On the back of the remote, press the battery compartment cover where indicated and slide the cover off. It may be difficult to remove
Dec 02, 2012 | Televison & Video
Sony internet tv remote stuck
open the remote control and clean the keypads from dirty, corrosion, oxide, and bad contacts, with c. cleaner very well. with carefully.
2) replace a new battery with the same type:alkaline
3) clean the contacts batteries with c. cleaner
4) try again.
5) if the problem persist you have 2 options go to repair shop TV for fix it, or REPLACE IT.
God bless you
Oct 12, 2012 | Sony RM-VL1000 LCD Remote Control
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Change batteries in remote control and can not remote open
The sliding bottom must be placed exactly in its middle position so that the clips can more easily allow the bottom to be removed.
Aug 15, 2012 | Sony 1-487-700-11 Remote Control RM-ED035
Hi my name is Oscar I have a tv element model FLX-3211B and do not work the remote control codes sony RM-VZ320 and need help please!
Please reset the codes and try again. You must replace the batteries by new ones type alkaline b) clean the contacts batteries c) retight the spring contacts batteries with pliers d) open the remote control for clena the keypad switch from dirty, dust, oxide, bad contacts or open , remember they send infrared signal from Syscon to the microncontroler Receiver. see the blck..d
go to the next web pages, give your model, mark.
www.remotecodelist.com + remotes.com
God bless you
Jul 29, 2012 | Sony RM-VZ320 Remote Control
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
How to fix a Sony Tv RM-YD026 remote after getting milk in the buttons
take batterys out then take out the little screws in battery compartment pry open the two halfs clean the board and buttons and let dry dont wipe the carbon off it is the main part of the switch for the buttons just clean with water and let dry
Oct 20, 2009 | Sony RM-YD023 Remote Control
Televison & Video Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
