Question about Philips Magnavox TS3260C 32" TV
Picture is smaller, has hourglass shape, no sound
32'' Philips, Serial number 49715853Picture is smaller and has an hourglass shape, no sound. What could be going bad? Will cost between $90 and $200 to repair. Is it worth repairing? All other features work ok.
Took back off, removed control board and inspected for bad solder joints. found no obvious problem. Cleaned and reinstalled. Working ok now. I'm crossing my fingers.
Posted on Jan 28, 2009
I own a Philips 34PW8502/37, The picture is hourglass shaped, the images "bow-in" on the left and right of the screen
You have an East/West error caused by an amplifier that "modifies" the frame pulse and modulates the line scan to compensate for a tupe that has not got a 90degree scan.
Follow the scan coil leads and there will be probable dry joints and the pcboard or a power IC that has failed.
Hope this helps but a service manual will be of great assistance to you.
Nov 12, 2010 | Philips 34PW8502 34" TV
Philips 32PW6526C Picture problem
dried capacitors around the vertical IC output
Mar 06, 2009 | Philips 32PW6506 32" TV
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Philips 25PT2252
Vertical hold will adjust the frequency (refresh) which would remedy it if the picture was rolling. I had to open up my TV (not recommended unless you know what you're doing) and adjust a "pot" which will adjust your screen's hourglass problem. I hope this helps.
Jun 28, 2008 | Televison & Video
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
Hourglass shape on screen
you might tyr adjusting the eprom setting to correct the e/w pincushion fault,or call for service to adjust.
Nov 06, 2007 | RCA 32F531T 32" TV
Tv screen has slight hourglass shape
A common fault are some of the electrolytic capacitors failing in the pin cushoning amp section, and probably in part of the scan amplifiers.
To service this will require the proper training and set-up to troubleshoot the set.
Take the set to a service center for an estimate. The cost can be at least an hour or two for the labour, and then the cost of the parts on top.
Jerry G.
Nov 06, 2007 | Sony KV-32S26 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Rca f32450
Hi, It sounds like your TV has a Pincushion problem based on your post/description. There is a big chance that this is just a colder solder/loose connection but of course an on-site diagnosis would be better. Since this involve opening the unit and working on the electronics inside, I would suggest that you seek the services of a qualified TV professional.
May 24, 2007 | RCA F32450 32" TV
Hourglass Shape
Yes check for fluid leakage and see if the crt's are leaking fluid down on board. if so you have to change some caps any that got wet. If not wet at all then something that was fix maybe has a solder bridge on it look carefully and see if anything out of place
Oct 30, 2006 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox TS3260C 32" TV Logo
124 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
