Question about Dell Inspiron 1526 Laptop
Cant get yahoo to load on my pc or my laptop
Wont go to yahoo.com, tried firewall and everything i know
  • 1 more comment
  • m203dude Jan 27, 2009
    I am able to go to all other sites
    I have avast a/v running
    windows vista
    wireless conn. (pc wont load yahoo either)
    all it says is ie connot load webpage (tried refresh, checked firewall)
    running IE and fire fox
    I dont understand your last request
  • Celenous May 11, 2010
    "Assuming Windows take a look at the file below and post it's contents. This should open with notepad.
    c:\windows\system32\drivers\etc\hosts"
    There is a a file "hosts" located in the directory c:\windows\system32\drivers\etc\ you might need to modify this file to get this to work.
    What anit virus software are you using btw?
    I'm assuming that this happened recently. Have you added any new software or downloaded anything?
    Please post the exact error message you get.
    By default, if you try to modify your hosts file
    in Vista, it will not let you save it. It tells you that you don't
    have permission. To successfully modify the hosts file, run
    notepad.exe as an administrator and open the file.
    1) Browse to Start -> All Programs -> Accessories
    2) Right click "Notepad" and select "Run as administrator"
    3) Click "Continue" on the UAC prompt
    4) Click File -> Open
    5) Browse to "C:\Windows\System32\Drivers\etc"
    6) Change the file filter drop down box from "Text Documents (*.txt)" to "All Files (*.*)"
    7) Select "hosts" and click "Open"
    8) Make the needed changes and close Notepad. Save when prompted.
    Assuming you can go to other websites like www.cnn.com correct?
    Do you have anti-virus software running?
    What Operating System are you using?
    How are you connecting to the internet? Dial Up? Cable? ADSL?
    What happens when you try www.yahoo.com?
    What happens when you go to yahoo.com?
    Which browser are you using? Internet Explorer, FireFox?
Desktop software wont load my applications
First thing to try is disable the computer firewall and virus scanner.
Feb 10, 2014 | Blackberry Cell Phones
Cannot download Yahoo Messenger in y PC
It is a problem with your windows firewall. Try to turn of your firewall and then download the yahoo messenger and install it. Once the yahoo messenger is installed you can re-enable your firewall.
http://windows.microsoft.com/en-US/windows-vista/Turn-Windows-Firewall-on-or-off check this link for instruction on how to turn on and off firewall in windows vista.
Hope this helps
Best Regards NextDoorNerd
Jul 28, 2010 | Yahoo Messenger
I cant download programs such as skype and yahoo
Try to install the software with some other drive other than os drive .
Kindly rate my help+ Thank you
May 10, 2010 | Acer Aspire One D150-1587 Netbook
New ym version 10 wont install in my vista computer. something about firewall settings, how do i do it?
Try temporarily turning off your firewall,install yahoo,then turn the firewall back on,that may fix the problem
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
I cant sign in to yahoo messenger in my laptop, but other laptop can. how?
try updating your yahoo messenger for the laptop that wont run it and if it still doesn't work, try deleting it off completely and reinstalling it should work after.
Mar 02, 2010 | Yahoo Messenger
I cant installe yahoo messenger because of a fire wall.
Try use Yahoo Messenger 9, the latest version. Before download yahoo messenger, make sure firewall allows your connection to download it. It shows that your PC protected from any harmful software because of your firewall. One more thing download your yahoo messenger only for trustful sources websites, it much better. i think you should check your firewall settings. Check also your Windows Firewall. I think there are some problems in your firewall settings. It may be blocked your yahoo messenger from downloading it into your PC. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to install yahoo messenger,check it out, may be it blocked your yahoo messenger. I think this tips can be help you a little bit.
Good Luck!
Jun 01, 2009 | Yahoo Messenger
I think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger, check it out, may be it blocked your yahoo messenger services. Check also your Windows Firewall. I thick this can be help u a little bit
Try to find out this! All the best!!
May 31, 2009 | Yahoo Messenger
Yahoo messenger
try this
go to start/control panel/firewall and then set the firewall to the middle setting
Apr 27, 2009 | Microsoft Windows XP Professional SP3 Full...
Can't get yahoo messenger to download on my pc,tried everything,firewalls down ,pop ups off what else help?
Restart your computer and being again , go to www.http://yahoo.com/messenger and redown load again if u have windows 95 you will not get yahoo messenger.Need a up date computer.
Nov 26, 2007 | Microsoft Windows XP Home Edition
Dell Inspiron 1526 Laptop Logo
69 people viewed this question
Alun Cox
