Where is the p.zero button on sony rm-ed001 - Televison & Video
What's the difference between sony rm-yd028 or rm-yd065?
To most Sony remote controls, P+ / P_ & Vol+ & Vol -- ; buttons will work, except for other buttons will work. The difference between the Sony remote controls you mentioned here too will differ to these function. http://electronicshelponline.blogspot.com/
Oct 19, 2014 | Televison & Video
How do i switch off subtitles
Press the button to the left of the Zero key (0). It has a green square with green horizontal lines.
Sep 05, 2014 | Sony RM-ED009 Remote Control
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Where is the "ENT" button on a Sony rm-y915
it's the middle button with the arrows around it
Dec 26, 2010 | Sony RM-Y915 Remote Control
Code no.?
This information is to search for any code using the SONY RM-VL990T Universal remote:
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
May 09, 2009 | Sony RM-VL900 Remote Control
Sony RM-VL1000 stopped working
Dump the Sony "Integrated Remote Commander RM-VL1000" and go to WalMart (or wherever) and purchase any other brand and model for under $15.00.
You'll be so much better off!
Mar 21, 2009 | Sony RM-VL1000 LCD Remote Control
How do you program the Sony rm-p311 remote
You may wish to clear the remote's memory before starting. Slide the top left switch to "Learn." Press ANY button on the remote, do not worry if the indicator light flashes. Press the "Program Clear" button. The indicator should flash 4 (maybe 5?) times. You are now ready to program. Make sure the switch is in the "Learn" position. Place the rm-p311 and the remote you want to program in about 2 cm apart facing each other. Push the button you wish to program on the rm-p311. The indicator light should come on with a slight delay. Press and hold the button on the other remote until the indicator light goes out. Put the slider back to "User" mode and test it! For more info., go to sony's support site and search for the user manual for the STR-AV1070 receiver. It contains instructions for the remote.
Jan 11, 2009 | Televison & Video
Tv code
www.usersmanualguide.com/sony/remote_controls
Nov 04, 2007 | Sony RM-V310 Remote Control
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
