Question about RTO Exercise & Fitness
Auto shutdown doesn't work - RTO Exercise & Fitness
My computer still functioning even its shutdown already
have you tried to hold the power button down for 5 seconds? if that doesn't work, it's possible that when you click the shut down the last option used was the hibernate option. when you click the orb click the arrow pointing to the right next to the power indicator and make sure it's set to shut down and not hibernate
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Aug 02, 2012 | Lenovo Computers & Internet
My acer laptop suddenly shutdown then it didn't turn on,the led of the charger is blinking,what is the problem?
you may have had a surge on your charger, i'd unplug it and try a different outlet. After you unplug it, remove the battery for about a minute, then when at the new location plug the battery back in and then the charger. see if that works. if it doesn't it's possible that your charger just died. Did you happen to look and see how much battery you had available when it died?
May 14, 2012 | Computers & Internet
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
May 02, 2012 | Sony Computers & Internet
My computer doesn't want to shutdown and I was using CMD comands to shutdown it ; but when I have installed again the OS in the computer ; it has begun issue in shutdown again ; but I can see tha
Try to press and hold the power button to turn it off. If there's an issue, hopefully a blue screen will show up and it will attempt to troublehshoot it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Apr 26, 2012 | MSI Computers & Internet
When logging off my laptop, and before going into shutdown, I closed the lid on my laptop. The window is now stuck showing the prepare to shutdown screen. The mouse pad still works but nothing I push will...
Try holding down the power button until the computer force shuts down. If that doesn't work, you may need to pull the battery. Don't worry about damaging files, everything should be fine. When Windows boots up again, you just need to select "Start Windows normally".
Aug 14, 2011 | IBM ThinkPad T60 Notebook
I cannot find the shutdown it disappear because of a certain download,now i dont knw how to shut may desktop....plz help i am so sleepy already
Try pushing the power button once, briefly. It should trigger the shutdown sequence. If not, try hitting Ctrl, Alt and Delete at the same time. That should bring up Task Manager. You'll find shut down in there. If that doesn't work either, all you can do is push and hold the power button until it shuts down, usually about 4-5 seconds, or pull the power plug.
Jul 07, 2011 | Computers & Internet
Power lights flashing,will not stop
Ok sir try to turn off the printer if it doesn't. Pull the power cable shutdown your computer then plugged again the power cable of the printer then turn on the pc and printer..If it doesn't change contact a printer technician or bring the printer to the nearest service center. Hope it helps you..
Jul 01, 2011 | HP Office Equipment & Supplies
My screen doesn't work, it is sleeping. What can I do ? After I took a rest my screen dit nothing. Whatever I trie, it doesn.t light up.
Try restarting your computer, If it happens again, try to find a pattern in the problem. If you can't restart, hold down the power button for a few seconds to do a forced shutdown.
May 12, 2011 | Acer Aspire One PC Notebook
Dometic Americana RM2852 refrigerator does not work. Has power to it, light inside works and lights at top indicating 'AUTO' mode are illuminated, but refrig doesn't work in any mode. Gas is...
Have the same unit but experience no problems. Sounds like a freon leak has left it inert. You can of course switch from auto to gas and eliminate the auto switch over as part of the problem. You can see the gas flame in the outside access hatch, (or maybe hear it) to be sure it is getting gas. since it doesn't respond in auto, which would also work in electric mode, I think it is the freon problem.
May 11, 2011 | Dometic RM2852 Refrigerator
Exercise & Fitness Logo
19 people viewed this question
Top RTO Exercise & Fitness Experts
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
