Question about LG LFX25960ST Stainless Steel French Door Refrigerator
I bought LG fridge LFX 23965ST 3 years ago. It was fine till last summer. Firstly, it stopped producing ice, and it made noise when I pushed the ice button. About two weeks ago I noticed that the wate
I bought LG fridge LFX 23965ST 3 years ago. It was fine till last summer. Firstly, it stopped producing ice about 6 month ago, and it made noise when I pushed the ice button. We knew that the repair is costly, so we lived without ice. About two weeks ago I noticed that the water is dropping from the fridge french door onto the freezer's door top, and after that the freezer stopped working. In two days the fridge did not make any cold and at the opposite, the temperature inside the fridge was significantly higher than in the kitchen. What can be a problem and does it worse repairing it?
3 Suggested Answers
  • 489 Answers
SOURCE: Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Posted on Sep 30, 2008
jeffbvegas1
  • 520 Answers
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Posted on Jun 26, 2009
Defrost heater do not defrost creating poor air circulation
for starter call viking with your mod and ser #
there is a hinge recall on fridge door is covered by warranty regardless of age
it can cause the air channel from freezer to fridge to ice over due to too much humidity entering fridge
this stops cooling in fridge
the viking warranty starts from the day you took possession
defrost heater almost never
sounds like you need a better servicer
ask viking for other auth servicer in your area
gl
Apr 07, 2017 | Viking DFBB363L (20.3 cu. ft.)...
I bought my samsung rsa1wtmh fridge/frezer over two years ago and it has been troublefree for all that time. Over the past two days it has now developed what I can only describe as a motor noise behind the...
YOU MORE THAN LIKLEY HAVE A OVER FROST PROBLEM
ie freezer has made to much ice , you probaly will only need to switch off for 24 hours to let excess ice to defrost ....
click here for
samsung fridgefreezer problems
also have alook at .......
rsa model really only developes this type of problem , which as i said can be easily sorted by allowing appliance to defrost ...">
Oct 22, 2010 | Kitchen Ranges
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
LG LFX 25950SB, the Ice Maker is not working, just hear a click
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
I have an LG fridge top / freezer bottom which I purchased exactly 3 years ago. The fridge has stopped cooling, although the inside light stays on. Also, the freezer is still working perfectly. Firstly,...
Most LG fridges have a 1 year warranty with some components exteneded, such as the compressor or sealed system repair. Those are usually 5 years or long, depending on the model.
Can you tell me the temp. in your fridge please? I have a strong suspicion that it may just be the thermostat.
Feb 03, 2009 | Refrigerators
Ice maker LFX25960ST
3 months old?? warranteed for a year call for service , you bought new so you wouldnt have to fix it!
Oct 31, 2008 | LG LFX25960ST Stainless Steel French Door...
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Several problems with ice maker
i suspect he real problem is that the freezer is not defrosting. its difficult but take off thge back panel in the freezer and see if there is ice build-up on the pipework behind.if so melt it off with a hair-dryer and check also that the drain is clear. the water you have had on the floor could be due to intermittant defrosting
Mar 14, 2007 | Hotpoint HSS25GFP Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
47 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
