Dell Motherboard
Problem for Dell (8N816) Motherboard
Power Supply Issues
By khaygood on Jan 27, 2009
My Dell Inspiron works perfectly fine on the dock. When I use it away from the dock, though, the power "comes and goes" and the screen flashes dim then bright repeatedly. Eventually I see that my battery is not charging. I have replaced the external power cord and that doesn't seem to help.
Comments:
Jan 27, 2009
- Thanks. The problem is not with the dock. It never leaves my desk at work and the laptop works perfectly fine on the dock. It's when I use the "cord" power supply away from the dock. And it does the same thing no matter where I plug it in. However, you have posed an interesting issue. The dock DOES have a "grounded" plug, while the portable cable does not. Hmm
Clarification Request
Posted by Qabal on Feb 24, 2009
If you move/wiggle the plug around, where it goes in to the back of the computer, can you get it to start charging again?
Posted by candymangand on Jan 27, 2009
NEED MORE INFO.
I AM THINKING THIS MY BE A GROUNDING ISSUE, NOTHING YOU DID BUT DELL CONFIGURATION, TRY PLUGING THE DOCKING STATION SOME WHERE ELSE, DIFFERENT HOUSE OR BUILDING, IF SAME RESULTS
THE SYSTEM IS SETUP A GROUNDING THREW THE DOCKING STATION, WHEN YOU PLUG INTO ANOTHER OUTLET THE GROUNDING IS NOT SETUP PROPRLY IN THE ELECTRICAIL SYSTEM, THAT MAYBE A SAFTY ISSUE AND YOU MESS WITH IT AND YOU MAY NOT GET COVERED UNDER WARRENTY SERVICES IF YOU HAVE NO WARRENTY ISSUES THAN YOU WILL HAVE TO PAY SOMEONE TO HELP YOU SOLVE THIS ISSUE DOWN THE ROAD.
CANDYMANGANDY
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (8N816) Motherboard?
Answer
Answer
can you you tell me how i can fine a wedsite with a clear motherboad diagram with a step by step... (More)
Answer
what type of motherboard for HP Compaq dc5700
Answer
Where would I get a manual or full spec for a SCI36-r13 Dell motherboard can't find anything on... (More)
Answer
i need to know the diferent pins on the mother board so that i can convert another fan in the board
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
