Question about Sharp Notevision PG-A10X Multimedia Projector
Sharp PG - AX10 Projector - Fault Lights
I am currently having an issue with said projector, it turns on fine but when you go to turn it off for a break and then go to turn it back on again both the power and lamp light, light up in red and it switches its power off! Why is this? How can I solve the problem? I have cleaned the filter, and I don't think the lamp is about to die as the instuction manual informs me that it will tell me on the screen weather or not the lamp is about to fail. Regards confused David
dhiman
  • 115 Answers
SOURCE: sharp digital multi media projector PG M10S repairs
pls tell the problem clearly as this is solveable
Posted on Mar 29, 2008
SOURCE: my projector says all keys are locked.
Just hold the "ON" key for 3 seconds until it frees up the keyboard. Then hit the "standby" button twice to shutdown.
Posted on May 08, 2008
Sinista
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Posted on Jul 10, 2008
SOURCE: Sharp Notevision PG A10X
check the power supply heard issues with this system like that but was all related to the power supply
Posted on Jan 24, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Posted on Jul 23, 2009
I have a sharp notevision DLP xr10x projector. Two red lights, one is the lamp, the other standby/power. I changed the lamp but nothing changed. I can't even turn the thing on. Any ideas?
Hi Stephen,
Do you hear any fans starting when you turn on the projector? Try unplugging and then plugging in the projector. Make sure that the lamp door is secured as the projector will not start if it is loose. You should also reset the timer for your projector. The manual can be found on the site of www.allprojectorlamps.com.
Nov 04, 2013 | Sharp Notevision PG-C45X Multimedia...
Sharp projector pg-d3050 not getting on, only led turns green for a while and then turn red?
I had very similar problem with a Panasonic PT-LX22 LCD Projector, try changing the lamp, this worked for me.
Oct 08, 2013 | Sharp PGD3050W: PG-D3050W Multimedia...
Powers off automatically
Please check the filter to the lamp, clean and reset. A poor cooling of the lamp can cause this issue . Secondly a failing lamp also is a reason. If there is no result then you must check with the service center for a consensus .
Nov 02, 2011 | Sharp Notevision PG-C20XE Multimedia...
Rest light imer on sharp pg c45x
Turn on projector, press and hold the input, enter and undo buttons on
the projector then while still holding those three press the on button. Make sure you do this before the timer goes to 0% or it wont turn on again.
Apr 21, 2011 | Sharp Notevision PG-C45X Multimedia...
Sharp XG-C50X Notevision. Doesn't get past "warming up"
it seems that the powersupply is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 21, 2009 | Sharp (BQCXGC50X1) Projector Lamp for...
PG-C45X projector wont power on
To solve this problem, simultaneously press the "Input", "Enter", and "Undo" buttons. While holding these buttons, press "On". When the project turns on, you should see "LAMP 100%". This indicates that you have successfully reset the lamp life timer.
Nov 17, 2008 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp PG-M10X projector
Tel 703 377 7121 Hi Allan
It might be a digital or optical problem. This symptom was often part of the CRT type projector setup but i have not seen in the digital single lens type.
Is the lamp sitting 100% proper. Have you displayed the content machine and source on another display device? Was the machine dropped or knocked? It is an unusual symptom to have just be replacing the lamp..so something else has occurred.
If a digital problem in could either be a circuit malfunction or software (IC rom issue)
Re your Sharp PG-M10X We are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
May 23, 2008 | Sharp Notevision PG-M10X Multimedia...
MULTIMEDIA PROJECTOR
This sounds like a faulty Mainboard
Apr 08, 2008 | Sharp Notevision PG-M20S Multimedia...
Open Questions:
See all Sharp Notevision PG-A10X Multimedia Projector Questions
Sharp Notevision PG-A10X Multimedia Projector Logo
113 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
