Question about Garden
How to install keikhinkt carburetor - Garden
How do I connect the throttle to the carburettor on la125100 series
THis provide that it still the Briggs 331877 on it
Install Carburetor
NOTE: Always replace air cleaner gaskets and carburetor mounting gaskets any time the carburetor has been removed for service.
1. Position new gasket on studs with long edge of gasket opposite fuel inlet of carburetor.
2. Hook governor spring in throttle lever hole without grommet. Hook governor link in throttle lever hole with grommet.
3. Hook choke link into outer hole of choke shaft from underneath. Slide other end of choke link into slot in governor control bracket.
4. Position carburetor on engine. Install Carburetor to intake screws or nuts and torque to 70 in- lbs
5. Connect fuel hose to carburetor and secure with hose clamp.
6. Using new gasket, install air cleaner assembly to carburetor.
Adjust carburetor, if applicable.
7. After final carburetor adjustment, use Knockout Pin #19135 to install new limiter cap with flat side facing up.
Jan 08, 2015 | Garden
Just installed a new carburetor on a Tecumseh Snow King 8 hp engine. Gas is getting to the carburetor but no gas is filling the bowl and engine won't start
Sounds like the carb needle valve is stuck closed. Try loosening the bolts holding the carb to the engine, then tapping the carb lightly with a hammer. If gas then flows to the carb, re-tighten the carb bolts evenly and not too tightly.
Dec 27, 2014 | Tecumseh Garden
How to install choke lever spring and butterfly
I suggest you type on the command line of your computer or I phone wilbro carburetor diagram . It will lead you to a web page with a diagram showing the assembly
Oct 04, 2014 | Craftsman Used Walbro Carburetor For Model...
Carburetor installation
I'm sorry, if this isn't simply, openly, obviously, easy for you... take it to a professional.
Apr 17, 2014 | ATVs
Cyl fills up with gas after shut down to re-start must remove plug drain cyl re-install plug then mower runs fine??
Sounds like the inlet needle in the carburetor is stuck open. If you are lucky, you can give the carburetor a few taps near the fuel inlet area. (A few taps doesn't mean hitting it with a sledge hammer.) If that doesn't work, remove the fuel supply line from the carburetor and give the fuel inlet on the carburetor a shot of compressed air.
If the problem still persists, you need to replace the carburetor inlet needle and seat and be sure the float level is correct. I am assuming that you have not had the carburetor off and have not changed the carburetor float level.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Install reeds for yamaha bw80
You will have to remove the carburetor, then remove the intake manifold boot (what the carburetor attaches to the engine with).Then in the intake port will be the reeds in a cage. Install new reeds and re-assemble.
Dec 08, 2013 | Yamaha Motorcycles
String trimmer leaks fuel
the primer bulb could be your problem. easy to replace
Apr 06, 2017 | Garden
Fuel leaking out of 2 hoses connected to the carb cant stop the fuel leak
Inspect the fuel inlet hose closely. If you notice a wet spot around the hose where it joins the carburetor fitting, or the hose has become swollen, soft, brittle or hard, replace the fuel hose and the small fuel filter inside the carburetor fitting. Install a new worm clamp to tighten the new fuel hose to the fitting. Use a Phillips screwdriver.
Check for a fuel leak around the accelerator-pump cover assembly. Some carburetor models come equipped with a diaphragm-accelerator pump on the side of the unit. If the cover screws have come loose, fuel will leak through the diaphragm and external cover. Look for a square cover on the side of the carburetor and tighten the cover mounting screws at each corner with a Phillips screwdriver.
Look around the gasket located between the carburetor upper body and the main, or lower body. This gasket may have worn out or the carburetor upper body mounting screws may have become loose, allowing fuel to leak outside the carburetor.
Ensure the upper body mounting screws are tight, if you found a leak. If they are tight, remove the clip holding the throttle linkage to the carburetor with a pair of needle-nose pliers and reposition the linkage to the side. The linkage allows the driver to operate the throttle plates in the carburetor through a cable when depressing the accelerator pedal. Unfasten the screws holding the carburetor upper body from the main body with a ratchet, short ratchet extension and socket. Remove the old gasket and install a new one.
Inspect around the bottom of the carburetor where it joins the intake manifold if no leaks were found around the gasket located between the carburetor upper body and the main, or lower body. If you find a wet spots or marks around the bottom of the carburetor, the base plate gasket is leaking. Remove the upper and main carburetor body using a ratchet, short ratchet extension and socket. Install a new base gasket and replace the carburetor assembly.
Jan 21, 2012 | 2009 CCM RL 125
Need a pic and specs on a 1979 gmc sierra grande carburetor
That is a Rochester carburetor--4 barrel, and these carburetor are notorious for problems. It's a hassle to repair because some of the flat plug in the passage ways will leak. We just drill them out, and install new plug with epoxy after the carburetor body has been thoroughly cleaned. Go to you local library they should have a repair manual on Rochester carburetors, or look on the Internet it has everything in it networking. GB...stewbsion
Aug 21, 2011 | GMC Sierra 1500 Cars & Trucks
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
