Question about Sony VAIO VGN-N250N/B Notebook
Sony vaio pen drive troubleshooting
Hi.. i have sony vaio pen drive... its was working but not formatting device... so plz i want sony vaio pen drive troubleshooting application
Pen drive showing 0 byte
Do not use any more and get some data recovery freeware.
Sep 14, 2017 | Transcend (589307) Media
I have sony vaio but the av mode is not working and i have VGN-CS215J
Hi.
According to the information online, the issue might be due to the VAIO Launcher Application.
The VAIO Launcher Application is responsible for the functionality of the AV Mode keys.
Hence, it would be better to re-install the VAIO Launcher Application.
It is also recommended to install the Sony Shared Library before installing the VAIO Launcher Application.
I have mentioned all the links from which you can download the Sony Shared Library and the VAIO Launcher Application:
Sony Shared Library:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS215JW&upd_id=4236&os_id=34
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS215JW&upd_id=4403&os_id=34
Please click on the above links to download the Sony Shared Library and the VAIO Launcher Application.
Hope this helps.
Please feel free to contact for further information and assistance.
Nov 17, 2010 | Sony VAIO VGN-CS215J/W Notebook
Hi.... i have a problem wd my usb.(flash drive).... when i go to open it. its its give the formate message on screen.... when go to formate it ,,,, it doesn't format... and give unable to format option......
Use below commands:
Click on start
Run
Type :Cmd
Once done type ( DriveName .Format.exe)
Please check files on the pen drive perhaps windows is using some application on it ..
Nov 02, 2010 | Computers & Internet
Sony 4 gb pen drive
Hi friend,
You should scan your pen drive by any antivires because your pen drive have some vires so you are not able to format it...you should try other computer...
With Regards
Dec 31, 2009 | Sony Electronics - Others
Pen drive show 0 bite. But my pen drive is 8 GB. How i solve my problem?
Insert pen drive, right click on corresponding drive, then select format
format should fix it if the drive is not physically damaged.
Also, did you set your flash drive to speed up your computer or use as additional ram? if so that might also be an issue.
Oct 06, 2009 | Sony VAIO VGN-AR720E/B Notebook
Cannot transfer files in to sony 4gb pen drive
try a different usb slot ..if that doesnt works then it sounds like your pen drive is damaged .. that can happen in several ways .. if you carry it around with you, make sure the cap is on ... it can get static zapped otherwise .. also the gold fingers inside can get dirty .. another way the drives are damaged is to remove them while data is still being written to the drive ... wait until the light is no longer flashing before removing .. if you are using win98 or winMe .. then make sure you turn off the device before removing ..
Aug 05, 2009 | Sony Computers & Internet
Sony microvault 2 gb pen drive- can not copy file- I/o device err
My 2gb sony microvault is asking me to format. It is teeling me that it is write protected. How do I format it
Apr 16, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Sony vaio motion eye
I have windows vista sony vaio vgn fe880e buying at america, but I dont have drivers of motion eye web camera
Jul 06, 2008 | Sony VAIO VGN-FE880E/H Notebook
Pen drive not working
If your usb port is working properly your computer should pick up the the pen drive as soon as you put it in the usb port if not goto add and remove hardware and check to see if the diver is up to date .hope this works for you let me know ok
Feb 16, 2008 | Electronics - Others
Sony VAIO VGN-N250N/B Notebook Logo
188 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
