How to fix the processor in the motherboard - Computers & Internet
  • Saroj Sharma
    Saroj Sharma May 11, 2010
    Kindly provide details on system model, motherboard and processor
    Habit-Forming:
  • 34 Answers
You cannot fix a processor, the only way is by replacing, but in most cases if it burns or if something happens to it, the motherboard goes with it. You might want to ask before buying a new or used CPU if you can return it since your motherboard might also be bad.
Posted on Jan 28, 2009
Hi. I'm currently installing my intel core i5 processor chip to my gigabyte z68ma-d2h-b3 motherboard. Somehow the chip won't sit in correctly. Is this normal by any chance?
GIGABYTE Z68MZ-D2H-B3 motherboard has LGA1155 Socket
Below are the 2 videos illustrating the board socket and processor details and the procedure of adding the processor. Watch carefully and fix the processor.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 09, 2011 | Intel Motherboard
Long beep continues and it wont boot
HI
Please check your processor is supporting in your motherboard. and check the RAM also its fix properly some time if u not fix the RAM properly the same ERROR is coming..
Good Luck
May 11, 2011 | EliteGroup Intel Pentium 4 Processor...
I have a Compaq Presario SR2011WM which powered down on me. I get a solid light in the back and when I hit the power button I get a solid light on the front also which will not shut off unless I unplug it....
Well, unplugging something (I'm not quite clear on what you unplugged), especially if it supplies power to the processor usually doesn't fix things. If you mean the plug that looks like http://www.pcguide.com/byop/diagrams/figure9.jpg then it helps supply power to the motherboard, and I'm not sure what unplugging it would fix but it is more likely a motherboard issue than a processor issue if unplugging it fixed the problem. Regardless because this is an older and off the shelf computer upgrading it will be difficult due to the fact that celeron's don't have the same socket type as newer processors. If it is a motherboard issue then you will need a new motherboard and a new processor for that motherboard. Essentially the easiest and most cost effective thing would be to get a new computer.
Feb 28, 2011 | HP Compaq Presario SR2011WM PC Desktop
Display problem
remove your processor and the processor fan clean the processor surface with a clean cloth and fix it to the socket apply a thin layer of heat sink compound and fix the heat sink firmly to the processor remove your memory card and clean it with a neat cloth and insert it in the slot and restart the computer still not working remove the memory module and restart your computer you will hear long beeps now insert the memory and restart your computer if you hear only one short beet and display not coming add an pci or agp graphics card if it work the problem is with your graphics section in the motherboard
Nov 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I am havimg a p4 processor.iwaan replace it by core 2 duo.will it be possible with D101GGC
This motherboard only supports the folloing processors.
  • Intel® Pentium® D processor 820, Intel® Pentium® 4 and Celeron® D processors in the LGA775 package
  • Supports Intel® EM64Tφ
  • Jul 07, 2010 | Intel D101GGC Motherboard
    CPU Running Fan not recognized by motherboard M7VIG 400
    Check out
    1.the heat sinker is tightly fixed on the processor.
    2.check and clean the dust in the processor ad the coolingflood on top of the processor
    Jun 30, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
    Alwyas get to bios cpu freq and hang
    try clearing the bios and replace the bios battery.
    Check the processors correct frequency and set it in the bios and save settings this should fix the problem.
    Also check if your cooling fan on the processor is tightly fixed onto the cpu and motherboard
    Dec 01, 2009 | ASUS P4S333-VM Motherboard
    Is it compatible a intel dual core processor to a
    Hi..
    If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
    Good luck !!!
    Regards
    PCmania
    Jul 15, 2009 | ASUS P5PE-VM Motherboard
    Plz help me out...problem in assembling AMD Athlon 64 processor in KVM800M board
    There is no fix for that. You need a board that is the same as the original because that is the size of the processor. If that is a socket 462 processor, it is only designed and will only run in a motherboard with socket 462 on it. You need to either replace the processor or replace the board with the correct one.
    Jul 03, 2008 | Mercury KVM800M Motherboard
    Computers & Internet Logo
    60 people viewed this question
    David Payne
    David Payne
