Question about Kenmore Elite Sears & Other Brands Replacement Gas Grill Stainless Steel H-Burner
Service bulliton model 795.72063.110 - Kenmore Elite Sears & Other Brands Replacement Gas Grill Stainless Steel H-Burner
When the air conditioner or heater is turned on, it works on all speeds but only blows out of the defrost and very little at the door vents. There is next to nothing blowing out of the front facing...
check enviromental switch on dash for power or vac.there is also a tech. service bulliton or tsb for this problem. just search tsbs for your vechicle
Nov 03, 2013 | 1999 Plymouth Grand Voyager
I have a 2003 Impala. My heater/air will only blow through the dashboard and not on defrost area Not sure what part that is and can it be replaced by taking off the dashboard?
most likely your control switch on dash. once pulled ck vac and voltage. seen a lot of bad switches. you can search tech. service bullitons or t.s.bs I know there is one out there for this issue
Nov 03, 2013 | 2003 Chevrolet Impala
My Corsica stalls when about to stop.
Samething happend on my 94. The dealer told me ther was a service bulliton. Never went to print Mechanic just have common knowledge of this problem. It is the CPU it may need resetting by the dealer they have he proper equipment to reflash it. If is faulty it can cause all kinds of weird stuff. From making your engine light go on or off to slow turn signals to making your engine stop at idle. But high engine temp is the most common due to the CPU. Have it checked out by the dealer . Don't spend your money on alot of bogus fixes. I am having it done again the CPU just does not hold the programing. I will never buy another Chev without reading there Service Bulletions first.
May 05, 2012 | 1993 Chevrolet Corsica
My paint is peeling off my 2004 black galant
thats a sign of not enough clearcoat from the factory or just a bad batch. i would bring it in to the dealership and tell them cause there might be a bulliton on it and the manufacture could pay to have it repainted.
Mar 11, 2011 | Mitsubishi Galant Cars & Trucks
1992 chevy blazer 4.3 vortec engine 2w dr have change the fuel pump fuel filter spark plugs rotor in the distributing cap ignition coil.and still doesnt want to start only cranks but doesnt stay on.
Check the wireing to the pump they had problems with it it tended to over heat and corroad there is a service bulliton on the prroblem #25215705and a kit with new wires and connector to resist over heating Icould give you the kit # but i got a DELPHI pump and the connector dosn;t fit a chevy pump
Nov 23, 2010 | 1994 Chevrolet S-10 Blazer
2007 Dodge Caliber BACK end squeak. All sorts of squeaking coming from the back. Mostly over bumps. Its like a low pitch squeak. Any idea what this is?
squeaks,rattles hard to diagnose from afar but have you tried wd40 on one rubber bush at a time until squeaking stops,when it does,youve found it.....
May 06, 2010 | 2007 Dodge Caliber SXT Sport Hatchback
Underbody rattle/buzz during hard acceleration. Could it be a loose heat shield for the exhaust?
theres a service bulliton that replaces the piece of flex pipe on the exhaust. also i have seen rocks get in the cat converter heat shield and do the same thing
Oct 01, 2009 | 1996 Honda Accord
Error code 0159:0061914
I couldn't see a 159 error in the 2000d service manual, but I know 150 errors . They need to have their firmware updated, should be under warranty, their is a kyocera service bulliton on this issue so all agents can do your repair. It is just a matter of downloading firmware from kyocera. unzipping it to a mem stick or CF card and powering on your printer with it inserted, firmware then self installs.
The bits after the 159:is just page counter. Post Email if you want me to send you zippped firmware to suit.
Dec 21, 2007 | Kyocera FS-2000D Laser Printer
Open Questions:
Kenmore Elite Sears & Other Brands Replacement Gas Grill Stainless Steel H-Burner Logo
116 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
