Question about Intel (8W501B1M3G) CPU Fan, CPU Cooling Kit, Cooling Fan
How to fix the microprocessor in the motherboard?
How the processor can be fixed in the motherboard
  • ROD GANDY May 11, 2010
  • Celenous May 11, 2010
    Before anyone can answer this you will need to tell us what the make and model of the motherboard is and it would be good to tell us the make and model of the processor you want to put into it. With this information someone can easily tell you the steps to installing the cpu, heatsink, and fan.
I need audio drivers for AMD Semprom 2600+,MMX,3DNow,~1.6GHz
There are no audio drivers for a microprocessor, you need audio driversfor motherboard. Kindly let me know the motherboard manufacturer and model number.
May 02, 2011 | AMD Sempron 2400+, 1.667 GHz (sda2400box)...
How do you fix a microprocessor that has come loose from the motherboard on a ps3. Model CECHH01
I would say to get some liquid Rosin/flux no clean kind and rflow the board with a heat gun. Which processor came loose?
Feb 24, 2011 | Video Game Consoles & Games
Hello there . I have the foxconn 661FX7MI-S motherboard. I wan to upgrade the celeron cpu. What is the fastest processor that is worth putting in it. Also will I be able to use the same fan or will I need...
This is the spec for your motherboard microprocessor......
Supports IntelĀ® Prescott-T processor in an LGA775 package
Supports FSB at 533MHz/800MHz
Supports Hyper-Threading technology
Feb 10, 2011 | Foxconn 661FX7MF-S Motherboard
Will a AMD Athlon 64 processor work in a Compaq Presario SR1050NX Desktop? My old processor Died and I purchased one of these off of Ebay, now just want to make sure it will work...
No Donnie, the motherboard for the Compaq Presario SR1050NX won't support an AMD Athlon 64 processor.
The reason why is;
A) The Processor socket on the SR1050NX's motherboard is a Socket A. (Also known as Socket 462)
Hp Support > Compaq Presario SR1050NX > Specifications > Motherboard Specifications >
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short.
Look to the right of the CPU heading:
Socket A (Processor socket)
This is the Socket A processor socket used on your motherboard,
You can click on the photo of the Socket A processor socket, to the upper Right, to enlarge.
The AMD Athlon 64 line of processors came out after the Socket A, and used the Socket 939 first.
Then on to the Socket AM2.
(Socket 940 for some models)
List of AMD Athlon 64 Microprocessors,
Oct 12, 2010 | Compaq Presario SR1050NX (DW257A) PC...
Need the specs for HP DV7 Laptop motherboard #486542-001. Most interested in what AMD Turion X2 cpu's this motherboard supports
Microprocessor 2.26 GHz Intel Core 2 Duo Processor P8400
Microprocessor Cache3 MB L2 Cache
Memory 4096 MB
Memory Max8192MB
Hard Drive 320 GB (5400 rpm)
Take care.
Jun 01, 2010 | Computers & Internet
I want to try to Instal a second AMD Microprocessor
sorry not posible theres only one slot on the motherboard for the chip.
apart from that theres a heat issue and power supply and .....
if you manage to do the upgarde there will be no space to allow proper cooling,
two chips will definately need cooling .
New body might be required to accomodate all the extra parts too,
Cheers Misterdj
Apr 09, 2010 | AMD Sempron 3000+, 1.6 Ghz (SDA3000AIO2BA)...
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
Hyperthreading Technology.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
Apr 13, 2009 | IBM (25P3294) Motherboard
It will support any processor that uses Socket 754.
Jun 26, 2008 | MSI K8MM-V Motherboard
Ventilator of the microprocessor
Most modern motherboards include temperature sensors that can speed up or slow down the CPU fan depending on how hot the processor is. If its noisier than it was originally it could be: -inefficient cooling caused by dust accumulating in the heatsink under the fan. -could be heat buildup in the case itself causing the processor to run hot. -could just be noisier because the bearing in the CPU fan is wearing out. -Make sure the CPU fan power cable is plugged into the proper socket. If it?s not the motherboard cannot control the speed. Let us know if you have any other questions.
Jul 09, 2007 | Thermaltake Intel LGA775 1/2U Solution...
Intel (8W501B1M3G) CPU Fan, CPU Cooling Kit, Cooling Fan Logo
447 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
