Question about RCA 27V520T 27" TV
Turn tv on, shuts immediately off.
RCA 27" Mo#27R410T, Customer stated problem started with lines across screen horizontally, before a drop to single line across tv then wouldn't come on at all. Tv was brought in, I turned it on and it shuts right back off after 4-5 secs. I can hear sound before the shutoff and no video at all. I replaced vertical Ic chip but didn't make a difference. I'm thinking the flyback/tripler is the problem don't know for sure. Could use any help. Thanks. Wayne McEathron
  • Wayne McEathron
    Wayne McEathron Jan 27, 2009
    What do you mean "Cutting the power to the outlet " Unplugging and plugging the tv back in does not work.
  • Wayne McEathron
    Wayne McEathron Jan 28, 2009
    A little more than that wrong...LOL
Same problem with my 28 inch 16:9 CRT Sanyo. I usually fix it by cutting the power to the outlet and then it works fine. Had it into the repair shop - and of course it never acts up there...
Posted on Jan 27, 2009
  • Sideshow Bob Jan 28, 2009
    When I say I cut the power to the outlet, I shut off the breaker that feeds that outlet. For some reason the TV always works after that.
    I spoke with a repair tech who said that spikes in the power supply can cause this problem. I just bought the mother of all surge protector power-bars. Time will tell if my problem rests with my power outlet or the TV.
I have a 27 inches RCA TV (model:27R410T) , Firstable when i turn the tv on ,it works fine but just for about 2 minutes , after that video has gone , no video only audio ,and start changing channels...
It maybe some semiconductor IC got hot, need service or repair. It may repair itself if you leave it on standby for a month(at operating temprature a week)? This is low tempeature(the lower the temperature the longer the time) annealing or moisture curing technology, used by Nasa on transistor failure in satellites, or long range unmanned vehicles. You can always repair the unit later.
Aug 26, 2010 | RCA 27R410T 27" TV
Still can't get parental block to turn off on my RCA 27r410t. Have tried most of the steps found here on Fixya. Front panel is blocked also.
Unknown password-- ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
Feb 09, 2010 | RCA 27R410T 27" TV
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
TV has Sound but no picture
your tv set have a problem in the horizontal section of the board.have sound but no picture or no raster.contact your service tv technician to check your tv set.......anime'
Apr 05, 2008 | RCA 27R410T 27" TV
Green lines at top
well i think your husband is right. it might be three years old, but the sligtest damage can kill it. so what you need to do is start saving up for a new tv. sorry for waht happened. maybe somebody hit the screen?
Sep 01, 2007 | RCA 27R410T 27" TV
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
JVC AV-27790 - single horizontal line
Since Intermitant always inspect the vert ckt for bad solder connections. If not replace the output IC they're cheap and most likely the problem If you still have lines on the top or bottom I would replace all of the electrolytic capacitors in the vert ckt also. Without much test equipment rebuilding the whole little ckt is the best way to go.
Apr 24, 2007 | JVC AV-27790 27" TV
RCA 27R410T
hi Sounds like a dry solder joint on or near the flyback try here: http://www.eserviceinfo.com/ good luck windman
Mar 04, 2006 | RCA 27R410T 27" TV
Televison & Video Logo
173 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
