Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Water accidently poured into coffee dispenser
I accidently poured about a third of a small cup full of water into the coffee dispenser, have i caused long term damage ?, what can i do to resolve
thanks
Paul
  • bansheracer May 11, 2010
    Hi
    What part do you call the coffee dispenser? Is it the thing behind the door? Is it the thing that you put the ground coffee in? Is it the place that you put the whole beans? Just a clarification please.
If the machine is still working, then you are fine. If you can hear the grinder spin, but nothing is happening, then the water caked-up the grinder. It needs to be taken apart and cleaned. It is best to have this cleaning done by a professional. See the authorized service provider list and bring it in for service.
Posted on Sep 12, 2009
Is it difficult to make Turkish coffee?
it doesn't really matter what bean you use to make Turkish coffee, what really matters is the pot that you make it in. An Ibrik is a traditional Turkish coffee pot which you can fill two thirds full with water. Add sugar and a heaped teaspoon of coffee. The coffee creates a seal at the narrow top. As you bring it to the boil the coffee with foam. You should let it foam three times before pouring into small cups. Let the grounds settle to the bottom of the cup before you drink it and don't stir it just before drinking.
Feb 27, 2013 | Home
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Does not fill a full cup when I select the large cup. Water is pouring back into reservoir through the overflow line. What causes this to happen.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 01, 2011 | Keurig B60 Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Apr 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Vanishing water
Is this problem happening by chance after you have used the maker? If so the heat from the previous use may be causing the water to steam from being so hot and thus causing the pot to be only half full. the hotter the maker the more water evaporates. You might need to let it cool down in between pots.
Joe
May 19, 2009 | Bunn 10 Cup Home Coffee Brewer
My Keurig B60 is suddenly not dispensing water when a K-cup is in the machine. Dispenses fine with no cup in chamber.
I solved it by running the machine a couple of times without a K cup in it. The second time through, a few grinds ended up in the cup. After that, the machine works fine.
Dec 03, 2008 | Keurig B60 Coffee Maker
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
136 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
