Question about Panasonic KX-T7730 Corded Phone
The problem with our phone set is it will not allow us to call out on it as it is sayin CO not assigned but we need to make outgoing calls can you help please
  • 3 more comments
  • litchfield_s Jan 27, 2009
    As our main office is in wales and we are in the westmidlands we are the programmers for the syatem is ther no quick fix solution
  • CarlyKay Jan 27, 2009
    I have the same problem and have no contact details for the person who set it up.. I do not have the feature guide.. Can anyone please help as this is a company phone and the problem is urgent. Thank you.
  • sujil2009 Feb 17, 2009
    I have same problem please help if you have a solution.
  • Anonymous Feb 24, 2009
    what the solution man
  • adel x
    adel x Feb 28, 2009
    say it man what is wrong with u
    u know the answer bu tu need he write to u again
    come on
Hi Litchfield_s... I have found the solution... if you still have the problem, please post again... Carly
Posted on Feb 16, 2009
  • 124 Answers
Is this a company phone? If so, CO stands for Call Out. This error occurs when your main phone system has lost it's programming and there is no outside line identified. You'll need whomever works on your phone system to program it for you.
Posted on Jan 27, 2009
  • Bernie Thames
    Bernie Thames Jan 28, 2009
    I'll see if one of our other experts can help you out. Hold on for a while.....
Line not assigned
make sure that your service provider has installed 3 individual lines into the building
check that the 3 incoming lines are not all together in the plug at the wall
you may need a telephone technician to check it out
Feb 17, 2016 | Panasonic Kx-tda100 Kx-tda100 Digital...
KX-T7431 try to dial out and dispaly says CO Not assigned, I cannot answer calls either!!!! Hellllppppp
What has happened is that the CO1 CO2 etc buttons have not been programmed to dial the access code for an outside line. You can do this manually by dialling 9 then the number you wish to call. You need to enter the programing mode from the default extension usually EXTN 20 or 21. You need to go into the options and assign the digit 9 and a pause (P). The system will allow you to set different options such as if someone is on CO1 and another user dials 9 from another extension, the system will then assign the next free exchange line, again this must be programmed via the default extension. Let me know if you need further help.
Sep 04, 2013 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    What is dns unavailable. my phone is samsung B3410.. thanks for your help
    DNS is a wetting in your phone that allows you to send mail and to browse the internet
    You need to set a DNS address in the phone settings. Set it to google DNS as 8.8.8.8 or search for open DNS.
    Try the following:
    1) Settings
    SMTP (outgoing mail) Server for MTN: mail.mtn.co.za
    NNTP (usenet) Server: unknown
    Proxy/Cache Server: NONE
    DNS Servers: Automatic
    2)
    You have a incoming which should be for example gmail.mtn.co.za and outgoing as mail.mtn.co.za and user name and password need to be the same as your gmail account
    Good luck
    Aug 29, 2011 | Samsung B3410 Cell Phone
    The phone wont allow me to text send messages or make calls, however i recieve both calls and text messages.
    you must probably have your outgoing calls barred and the best way to do this is to go to settings and check for call settings and unbarr all outgoing calls, the default code is mostly 0000
    Nov 19, 2010 | Nokia 6300 Cellular Phone
    My samsung s5233 tuch screen phone show 'service not allowed' during outgoing calls but it can receive incoming calls.
    In the settings menu, you are able to disable the ability to make outgoing calls. You will need the security code for the phone in order to change this.
    Jun 23, 2010 | Samsung Star GT-S5233 Cell Phone
    Unlocked Samusng Propel Incoming & Outgoing calls, sms, mms
    you should take the phone into t-mobile center and have them assign the settings for the phone.
    May 29, 2009 | Samsung Propel A767 Cell Phone
    Call barring
    Use the network services menu for this...
    Use this menu to access network services. Please
    contact your service provider to check their availability and subscribe to them, if you wish.
    This network service allows you to restrict your calls.
    1. Select a call barring option:
    All outgoing: prohibit outgoing calls.
    International: prohibit international calls.
    International except home: only allow calls
    to numbers within the current country when
    you are abroad, and to your home country.
    All incoming: prohibit incoming calls.
    Incoming while abroad: prohibit incoming
    calls when you use your phone outside of your
    home country.
    Cancel all: cancel all call barring settings,
    allowing to be sent and received normally.
    Change barring password: change the call
    barring password obtained from your service
    provider.
    2. Select the type of calls to be barred.
    home country.
    provider.
    if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
    http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
    hope this helps :)
    Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
    Have to be near fax machine to recieve fax
    The Rings to Answer feature might not be set to answer after the
    appropriate number of rings for your office setup.
    If you have a voice mail service at the same phone number you use
    for fax calls, you must receive faxes manually, not automatically. For
    information on how to receive faxes manually, see receive a fax
    manually from a phone
    on page 48.
    If you have a PC modem on the same phone line with your
    HP Officejet, check to make sure that the modem’s software is not
    set to receive faxes automatically. Modems with this auto fax
    receive feature turned on will take over the phone line to receive all
    incoming faxes, which will prevent the HP Officejet from receiving
    fax calls.
    If you have an answering machine on the same phone line with
    your HP Officejet, you might have one of the following problems:
    Your outgoing message might be too long or too loud to allow
    the HP Officejet to detect fax tones, and the calling fax machine
    might disconnect.
    Your answering machine might not have enough quiet time after
    your outgoing message to allow the HP Officejet to detect fax
    tones. This problem is more common with digital answering
    machines.
    The following actions might help solve these problems:
    a. Disconnect the answering machine and then try receiving a fax.
    If faxing is successful without it, the answering machine might
    be causing the problem.
    b. Reconnect the answering machine and re-record your outgoing
    message. Make sure the message is as short as possible (no
    more than 10 seconds long), and that you speak softly and
    slowly when recording it. Try again to receive a fax.
    If you have a special ring pattern for your fax phone number (using
    a distinctive ring service through your telephone company), make
    sure that the Answer Ring Pattern feature on your HP Officejet is set
    to match. For example, if the phone company has assigned your
    fax number a double ring pattern, make sure Double Rings is
    selected as the Answer Ring Pattern setting. For information on
    changing this setting, see change the answer ring pattern
    (distinctive ringing)
    on page 63.
    Note that some ring patterns cannot be recognized by the
    HP Officejet, such as those with alternating short and long ringing
    patterns. If you are having problems with a ring pattern of this type,
    ask your phone company to assign a non-alternating ring pattern.
    http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
    May 20, 2008 | HP Officejet 4215v All-in-One Printer
    Group forwarding after a delay
    In memory block 4-1 for the extension's port, The Lkey for the CO line is lit green for immediate ringing, red for delayed ringing, and off for no ringing.
    In memory block 1-1-77 you enter the CO's delayed ringing timer in seconds.
    I wouldn't try and deal with seperating into tenants.
    What I would suggest is in 4-19 restrict outbound trunk access (corresponding Lkey for CO line is lit to restrict)
    For example:
    Stations 1-4 would not be allowed to dial out on CO lines 5-6
    Stations 5-6 would not be allowed to dial out on CO lines 1-4
    This way Company A is not tying up Company B's CO lines for outbound calls and vice-versa.
    Apr 09, 2008 | NEC Electra Professional ETW-16DC-2
    Panasonic KX-T7730 Corded Phone Logo
    873 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
