I WANT TO CONNECT MY LAPTOP TO BROAD BAND INTERNAT CONNECTION WITH USB PORT INSTED OF ETHERNET
    Master:
  • 505 Answers
U will need to buy a usb cord that fits into the modem to the laptop also you may require the moden software to install the usb cord
Posted on Jan 27, 2009
How do i find my access point name my broad band t-mobile & im working with windows 7 if any one can help that would to great thanks
Your "access point" means the thing that your computer connects to in order to get on the internet. An "access point" can be the dsl modem, a router or switch inbetween the computer and the internet connection or the point of entry to the internet - depending on what you are using to connect and get on line.
You mentioned you have a broad band connection with t mobile. Is this the T mobile home service link that gives you regular phone service and internet? If so - what is the name of the box your connecting your phone and pc to?
What is the name of the equipment that t mobile gave you to use that broad band link?
Are you using a desktop or a laptop? Wireless connection? or a wired connection with a ethernet cable (looks like a phone cable but a little bigger on the plug end)?
To answer my questions go back to your original problem posted on fixya and use the comment or reply link in blue.
Mar 26, 2011 | Sony Computers & Internet
I got a two day gold pass and a xbox 360 i also got tmobile broad band internet on my pc so how do i get started with xbox live without an adapter or do i need an adapter
Requires a Router/Switch
(2) ethernet cables
Using your PC as the main Internet Provider, connect one cable from the PC's ethernet jack to the WAN jack/port of a router. Next hook up your XBox to one of the wired 1-4 jacks/ports on the same router with the other ethernet cable.
Mar 09, 2011 | Microsoft Xbox 360 Console
My new laptop has ethernet a port and I only have dial up internet,how can I hook it up.
ethernet a port is used for broad/tribandband connection so subscribe to ISP & replace u'r dialpup or use both
Dec 03, 2010 | Computers & Internet
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
My compaq presario V2000 will only connect to dialup
To connect to your DSL internet you will need an ethernet port or wireless card on your laptop. Your laptop should have an ethernet port, it will look like a phone jack but a little bigger. In the off chance that you don't have an ethernet port on your laptop you can also purchase an ethernet to usb adpater. You may have a wireless card installed on your laptop, but if not you can purchase a usb wireless adapter. To use your internet wirelessly in your home you'll also need a wireless router. All of these things can be purchased at your local electronics store (walmart, best buy, kmart, frys) and usually are fairly easy to setup with the included instructions.
Feb 15, 2010 | HP Compaq Presario V2000 Notebook
How do i connect my 433i to internet wireless
Generic comment
Your question relates to a Home Based situation???
If your e-machine is wireless capable, you can enable this feature through the network settings in the control panel. You will of course need a wireless router and it will have to be connected to a broad band connection.
alternatively, if your machine has a ethernet port (looks like a phone jack only bigger, you may want to get a ethernet cable and connect directly to your modem or router.
I hope this helps you
a
Oct 04, 2009 | E-Machines etower 433i PC Desktop
Linksys router model WRT54GX2 SRX200 drops wireless connection on the laptop and the ethernet connection on the desktop. Connection drops for seconds then reconnects in seconds. By-passing the router and...
read on the router if its broad band , if is not , you will not be able to use it , so my advice to you is get aother linksys router with broad band on it .wish you all the best
Aug 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I have satellite broad band on the host computer with a lap top via belkin.how do I connect the two computers together as a net work sharing printer internet etc?
Hi and welcome to FixYa,
With the indulgence of jmichelsen4, two ways:
  • a router if the satellite modem uses Ethernet port;
  • a hub or crossover cable if the satellite modem uses USB port on the host computer.
Good luck and Thank you for using FixYa.
Dec 07, 2008 | Computers & Internet
Broad band hub
donn't connect the cable driect you use the 5port or 8port swicth then take a cble to modem to that swicth then how many computer you have to connect you can
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Siemens ADSL Modem(model- C2110)
siemens c 2110 modem 3 lights flasing continously what to do
Mar 08, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
David Payne
David Payne
