Question about Kenmore Refrigerators
Model no 795.5103 ice maker assembly
2 Suggested Answers
  • 969 Answers
SOURCE: Water continues to flow into the ice maker
Replace icemaker.
Posted on Jun 05, 2014
Kenmore coldspot model 106.71252101ice maker freezes ice but will not drop it does it need to be reset or what
The thermostat on the ice maker is out you will need to replace the whole ice maker assembly
Feb 14, 2015 | Kenmore Refrigerators
There is ice in the ice tray but will not dump
da7a4823-cd31-448f-bac2-11ff8c3d6b4e.jpgCan you confirm your refrigerators model number? If youre model is the KSCS25INSS there can be two possibilites. The Electronic Ice Level Control Board or the ice maker itself=> 2198597 Ice Maker Assembly Instructions on how to diagnose the ice maker and the Ice Maker Level Control can be found HERE I am here if you have questions, Thanks Sea Breeze
Oct 04, 2013 | KitchenAid Superba Architect KSCS25INSS...
Reset ice maker
7c3b8cbb-076b-4151-8484-231367a81955.jpg0ef80fea-be03-46a2-9d13-079d4e206d2c.jpg20a0932e-3a69-4ce7-8bf3-ad10bc82a262.jpgDoes the ice maker have ice inside the slots but will not drop the ice? What is the correct model number of your refrigerator? If the slots are empty try filling with tap water and once the water freezes and drops the ice and then does not refill with water that will point to the water control valve. If the ice maker does nothing it will be the ice maker that will need to be replaced. For the model JCD2389G uses the=> D7824706Q Ice Maker Assembly and the water control valve is=> 12001892 Water Inlet Valve I am here if you have questions....Sea Breeze
Aug 29, 2013 | Jenn-Air JCD2389G Side by Side...
Ice Dispenser on Kitchen Aid Model KSCS25FTBL has stopped working
It can be faulty ice maker assembly and needs to be replaced.
Sometimes it visually sees ok,but actually its worn out or cracked causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Refrigerator model rb215labp The fridge freezes, fridge drawers freeze, top shelf is too warm
Its not working.Two possibilities,either faulty compressor or issue with defrost assembly.Defrost cycle not working.
repairclinic.com
partsselect.com
These will help.
Thanks,.
The model for Scotsman ice maker is AFE400A-1B and it stop making ice. Can you help me diagnosis?
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Mar 15, 2011 | Scotsman Ice Maker WBin Flake Style water...
Had to disassemble ice crusher and lost order of reassembly
go to web sight . www.apdepot.com. put in your brand and model # look at the ice maker bucket assm. this will give you a picture af the proper assembly . pt # 12517801 .. **** .
Jan 05, 2010 | Refrigerators
My ice maker stopped making ice frigidaire model plhs269zdb1 ice maker model number is GSI-26
The simple and most expensive solution is to replace the ice maker assembly. They sell for between 50 bux on e-bay to 150 bucks at Sears. From what I have seen most ice makers fit the same category and they look like they are all designed and built by the same company!!
The main problem is the gear on the backside of the unit snaps off for various reasons like ice cubes getting stuck and causing the ejector rake to jam, thus overloading the flimsy gear and snapping it off. You can not purchase the gear however you can choose to buy a gear-head assembly for 80 or so bux.
http://www.appliancepartspros.com/part_details.aspx?part_id=3177342&pn_=8201515
shows a typical repair kit. Just enter your model number on their website to find the exact match for your ice maker.
I repaired the broken gear on mine using some structural epoxy. Here is a pic of the repair in progress, The green stuff in the center of the gear is the epoxy I used. Good Luck!!
Dec 29, 2009 | Frigidaire PLHS269ZD Stainless Steel Side...
Refrigerators Logo
20 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
