Hi sir, my acer travelmate 4061nwlci laptop gets off when power gets off. is this battery problem or accidentely some settings have been made?. pls help.
    Problem Solver:
  • 7 Answers
Have you checked your power saving settings in the control panel. In particular check that action taken when battery level reaches the set threshold percentage.
good luck and tell me how you went.
Posted on Jan 27, 2009
Acer travelmate 2700 bios password
Open your laptop in back pannal and Remove CMOS battery (in mother board) then shote the CMOS socket in ternal two connections.then insert cmos and set your lap
Oct 07, 2011 | Acer TravelMate 2700 Notebook
Password bloked in my laptop
Unplug AC power. Remove the battery. If there is a CMOS battery (a rarity for laptops now), remove that as well. Press and hold the power button for at least 10 seconds. Replace batteries. Reconnect AC power. Turn on machine. CMOS should be reset to defaults.
Apr 05, 2009 | Acer Computers & Internet
Acer travelmate laptop's driver.
you may give these ones a try they should work
Mar 22, 2009 | Acer TravelMate 2355LCi Notebook
Sir,i would like to upgrade my memory(256MB DDR2)for acer travelmate 4061nwlci pls inform if 1GB is compatible.pls help
Your System memory is upgradeable:
256 or 512 MB fitted as standard upgradeable to 1 GB of DDR2 533 memory, or 2 GB using two soDIMM modules.
Feb 23, 2009 | Acer Computers & Internet
Web cam not fond
Did you install the drivers for your webcam. Check in device manager if there is an exclamation or question mark against the webcam.
Jan 26, 2009 | Acer TravelMate 341T Notebook
Bios password for acer travelmate 2410
i have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
Sep 12, 2008 | Acer TravelMate 2300 Notebook
Acer 240 Travel Mate
well its all ur luck any way try the latest drivers from acer site
for vga card and bios also.. might help u in fixing it
May 12, 2008 | Acer TravelMate 240 Notebook
Rebooting my acer travelmate 2310
There would be four (4) components that could have been affected by the drop:
1. battery - pls check that the battery is snugly fit and mates with the contacts/connectors;
2. memory - normally inside a squarish panel/lid held by a screw or two. Inside would be one or two memory modules held in place by retaining side clips. Pls, try to do an R & R, remove and re-insert. You need to move the retaining clips partially sideways to release the memory. It might also be a good idea to clean the little gold pins with a pencil eraser;
3. video card (if separate from the motherboard) something similar to the memory but slightly bigger and square (compared to the rectangular memory strip);
4. hard disk - normally are simply snap in place and can easily be dislodged. It would normally be inside a rectangular opening covered by a panel or lid held by a single (or 2) screw(s). You can also perform an R & R here.
If your concern has not been corrected after completion of the above procedures, further diagnosis may be required. This could be aided by information on other symptoms, signs, beeping sounds, flashing light and any or all other indicators.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
