Question about Dewalt 18 Volt Compact Drill Kit
Who to change the bit on a dewalt dc720. - Dewalt 18 Volt Compact Drill Kit
2 Suggested Answers
  • 885 Answers
SOURCE: How do you remove the chuck from a dewalt dc720 if
The only way to get it off now is with a grinder and metal cutting wheel. Lock the drill body in a vice with the chuck out of the vice jaws. Wear safety goggles and do not stand or let anyone else stand in the plane of the cutting wheel while cutting, you will have lots of sparks and if the wheel breaks peices will stick into things. You have to make a judgement call but you want to cut just at the head of the stripped screw. It's a lot of steel to get there so be patient and work carefully to remove the tip of the chuck. Once the tip is cut off you may be able to grab what's left of the chuck with a vice grip or lock it in the vice and turn it off the drill. If not, you'll have to make a cut length wise in the chuck so you can split the base and remove it. Be careful not to go deep enough to cut into the anvil or back far enough to cut into the drill body and trans. After making the cut put a chisel in the cut and hit it, hard, until the chuck body splits.
Posted on Feb 21, 2012
How to change bit on drywall rooter dewalt
ROUTER????you should have two wrenches or one with a locking mechanisms on shaft----loosen nut----push bit in then pull out!!!
if doesn't work take the nut off and check the holding collar---possibly spray it with penetrate---tap it a few times & it should come out------GL
Dec 25, 2016 | Dewalt Drills
What is the best lubricant to use on my dewalt hammer drills please
It depends to where you want to apply your lubricant.
If you want to lubricate the chuck with the sds drill bit you simply add some cheap grease on the drill bit and the drill bit will slide easily on the chuck. On the other hand if you want to lubricate the sds drill machine then there is a special type super grease that you can buy from Dewalt in order to do so. Also since in order the super grease to be needed this means that you have used the drill a lot then also is needed to change o-rings, brushes and so on. So usually you have to ask for a service center to do it since they know how to do it properly and using the right kit.
Oct 18, 2014 | Dewalt Drills
Dewalt instruction manual
The black thing at the end is the "keyless chuck". Grasp it just behind the silvery tip of the chuck with one hand, and grasp the knurled ring just behind THAT area with the other hand. Twist the "front" hand counterclockwise while you twise the "rear" hand clockwise. That will loosen the chuck so you can change bits.
Aug 06, 2014 | Dewalt Dc987k2 Xrp 18volt 12 Drilldriver...
Magnetic Extension for Dewalt Drill Bit
I have the same problem and am thinking of cutting that extension to get it out. A real pice of !@#$$%
May 13, 2012 | Dewalt DCF815S2 12-Volt Max 1/4-Inch...
How do you remove the chuck from a dewalt dc720 if the screw is striped inside?
Feb 21, 2012 | Dewalt Drills
Trying to find out which batterys will work in the DC720 drill driver??? Scott
The DC9099 or part number 651034-01 ($105.00) is the battery you need.
It can be ordered here
http://servicenet.dewalt.com/Parts/Search?searchedNumber=651034-01
Or you can go to your local service center or Home Depot/Lowe's
Nov 28, 2010 | Dewalt 18 Volt Compact Drill Kit
The bit in my Dewalt 6.3 Amp Dry Wall Screw gun will not pull out, how do I get it out to change it and how can I change from a Phillips to a nut driver tip.
The bits are held by a spring snap ring that sometimes takes a lot of force to release.
Spray a little bit of CRC226 into the bit/chuck interface and grab the bit with a set of visegrips and PULL !!!
The CRC226 is available in a blue spray can at Home Depot in the electrical dept and fights rust. A can is about $2.70... make sure to get the 226 as there are other CRC products there.
Jun 27, 2010 | Dewalt 6.3 Amp Dry Wall Screwdriver
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
Having trouble changing dewalt 14.4 v xrp cordless drill bit
hold black chuck and put in reverse if dont work spay wd 40 in and around where drill bit goes and let sit a few hours
Sep 12, 2009 | Dewalt Heavy Duty XRP 1/2" 14.4v cordless...
How to change the drill bit for a Dewalt DW995
That tool comes standard with a keyless chuck so all you should have to do is grip the collar and turn it to loosen bit. If it is stuck you might try a rag of some sort on the collar and use the motor to loosen it up. Let me know if you need more help.
Jun 23, 2009 | Dewalt Drills
Dewalt 18 Volt Compact Drill Kit Logo
35 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
