Question about Sharp MX-3501N All-In-One Printer
Sharp MX-3110n multifunction code FK1
Maintanance required code FK1, FK2 and TK1
  • 3 Answers
SOURCE: Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
  • 54 Answers
SOURCE: I have a sharp copier MX2700N with an error code
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Posted on Apr 17, 2009
007tech
  • 95 Answers
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Posted on Jan 15, 2010
FixinFax
  • 3085 Answers
SOURCE: I HAVE A SHARP MX1800N AND THE CODE OF FK1 KEEPS
You have a bad FUSER unit....expensive!! It is not heating up.
Posted on Jun 14, 2010
  • 11 Answers
SOURCE: Maintanance required code TA
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you
Posted on Jul 13, 2010
Sharp mx-3110N keeps jamming
Hi Diana,
There could be a small bit of paper left behind from a previous jam that is causing the problem.
Depending on the location of the jam there are a variety of potential problems. If you could give me some info on the location I might be able to help you out.
Otherwise you will need to call a dealer to look at it.
Jun 27, 2016 | Sharp "MX-3110N Color Copier, Printer,...
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Dave.
Sep 25, 2014 | Sharp Mx-3100n Color Copier Super...
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
Error code l4-06
This is a laser error code. You'll have to have someone come out and service the machine. If you're in the Houston, TX area we'd be happy to be your servicing dealer. 281-351-5128 Skelton Business Equipment Houston Copiers
Feb 27, 2014 | Sharp "MX-3110N Color Copier, Printer,...
Sharp mx 3110n, all settings are at "Plain Paper", when print a worksheet from excel, does not print because settings say "Heavy Paper"
Excel treats each worksheet as a different print job. Make sure each page is set to the type of paper that you want to print on.
Under the Page Setup make sure the type is set for the correct type, as well as in the print driver.
How To Configure Sharp Print Drivers with Installed Options to print...
Oct 21, 2013 | Sharp "MX-3110N Color Copier, Printer,...
Service code: FK1
Since you neglected to state the type of device, make or model, I am assuming everything and sending you what I guess!
http://search.aol.com/aol/search?&s_qt=sb&q=service+codes+fk1%2Cfk2%2Ctk1&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 21, 2013 | Audio Players & Recorders
Code:fk1 sharp 2301 N
That is a maintanence code. Usually says that the fuser rolls are at a certain copy count.
Here is what to do.
Press in order on the consol. # * C * That will enter the machine into what is called SIM mode.
Then enter the number 24 then 4 for that code, then press execute. You may want to just do the clear all maintenance code too.
Apr 26, 2011 | Sharp MX-2300N Color Copier
Can you tell me what code FK1 means?
Your fuser has gone past 200,000 sheets of usage and it's time for a rebuild. You could reset the counter with sim code 24 but eventually it will clog up with waste toner and your rollers will tear up. Sharp has rebuild kits for your or you could just buy a new one.
Jan 07, 2011 | Sharp MX-3501N All-In-One Printer
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
Apr 17, 2009 | Sharp MX-2700N Color Copier
Sharp MX-3501N All-In-One Printer Logo
489 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
