Lexmark JetPrinter Z55 InkJet
Problem for Lexmark JetPrinter Z55 InkJet
Printer doesn't print even with new ink cartridges.
By Kui Jai on Jul 20, 2007
I am a very infrequent printer user. Our Epson Stylus 500 was great when new. I reckon the print head is clogged up and would appreciate a way to unblock it.
We have a Lexmark Z55 as well. First I was told that the refill inks have ruined the cartridges and the print heads. I have since put in Lexmark's own ink cartridges and it still doesn't print.
Please help.
Same Problem
Sep 04, 2008
-   my (HP) printer has never had a problem until now.
i refilled the ink and the printer says the cartridge is full, but no
ink comes out :(-   ambergini
Jun 24, 2008
-   I have done all the troubleshooting that the manul says to do, i.e., using the pc to clean the heads. I was told by a tech, that I have no idea on how to contact that they (the heads) need to be manually cleaned. Another said to just get a new printer. No money for the second option. Is there a way that I can clean the heads?
Alicia-   alidmc
Apr 16, 2008
-   hp 3210, same problem, always used hp ink, no black.  -   Guest
Apr 11, 2008
-   i have a hp 3100 series printer and i just put the new ink cartriges but it won't print.-   sensuous
Mar 21, 2008
-   I have a epson stylus c82 and that has new ink and still wont print-   Guest
Best Solution
posted on Mar 31, 2008
Helpful)
SteveNorth
Rank: Apprentice
Rating: 87%, 10 votes
Remember to remove the Seal Tape from the Top of the New Ink Cartridge as well as from the Bottom ! !
If a “Head Cleaning” cycle makes the Test Pattern worse, STOP.
Disconnect the Printer from the Computer.
Press the “Cartridge Change” button for ~ 3 Seconds.
When the Ink Cartridge Carriage travels to the Changing Position PULL THE POWER PLUG (NOT the “OFF” Switch). The Ink Cartridge Carriage should now Slide Freely on the Rail as long as it isn’t pushed to the Right so that it goes under the shelf to the “Homed and Locked” Position.
Fold up a Paper Towel (About 1 Sheet) so that its final width is about the same as the width of the gutter under the Print Head on the Carriage and so that it is thick enough when folded to contact and lightly press on the Print Head.
Saturate the folded Paper Towel with ~ 70% Isopropyl Alcohol and lay it in the Gutter.
Manually slide the Carriage and Print Head Over the wet Paper Towel. A slight amount of drag should be experienced if the thickness of the paper towel folds is Correct.
Let the Print Heads rest on the Saturated Paper Towels for a few Minutes or Hours. Too long a Treatment may pull out all of the Cartridge’s Ink: Check the Paper Towel Frequently to Assess if Ink is Capillarying out onto the Towel.
When the Treatment appears Successful remove the Paper Towel and Clean Up and plug the Printer power back in.
Run a Test Pattern via the Computer Connection WITHOUT first running the Head Cleaning Utility.
If the pattern isn’t OK, Try Running the Head Cleaning Utility to see if it makes it Better or Worse.
If Worse, Repeat the Alcohol Paper Towel Treatment: The Paper Towel may be Gently Pulled back and forth under the Print Heads to wipe them off.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 20, 2007
Helpful)
DonB
Rank: Apprentice
Rating: 84%, 6 votes
I agree with "buy a new printer". My first printer an Epson I threw away because it was impossible to get the head to work after it had been flooded. I have just bought a continuous ink system at £40 for a Epson 1290 which had not been used for a couple of months and no amount of cleaning/flushing (even with the head off the machine) will make it work.
If you buy a HP type machine with the heads on the cartridges at least when they go wrong they are relitively cheap to replace. Just my opinion.
Don B
Was this helpful?
Yes
No
Solution #3
posted on Jul 20, 2007
Somewhat Helpful)
jackboy
Rank: Wiz  Lexmark Expert
Rating: 77%, 4398 votes
Which are you talking about Lexmark Machine or Epson?
Lexmark are head in cartridge- new cartridge new head every time.-If you have refilled these and it does not work simply buy Lexmoark Carts- or a new printer.[possibly cheaper]
Epson print head are in the machine - these need cleaning out and a head cleaning cartridge set from any ink supplyeri will do it
or a home made oner like to illustration.
All printer keep their workability if used frequently and not allowed to dry out
Further info can be obtained from
www.fixyourownprinter.com.
Was this helpful?
Yes
No
Solution #4
posted on Jun 27, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
n idea
Popular Solutions for Lexmark JetPrinter Z55 InkJet
Questions and Unsolved Problems for Lexmark JetPrinter Z55 InkJet
Do you recommend Lexmark JetPrinter Z55 InkJet?
Answer
Answer
Lexmark Z55 printer: paper feed does not wor, motor turns, paper does not move.
Answer
epson 810 printer does not print but shows ink is ok
Answer
printer is not communicating with the computer. won't print I have removed black inkjet and put it... (More)
Answer
hi , could you help me please ? I have an epson stylus dx 4850 printer,I have been useing the j r... (More)
Answer
I installed a new color cartridge for my Lexmark Z55 printer and it won't align automatically or... (More)
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 16, 2008
I have a epson stylus c82 printer bought new ink for it, makes noise like it's printing but doesn't print anything?help
Comment by GJ Sandy, posted on Jan 05, 2008
The "ink" light is still blinking and the printer won't print.
Comment by Guest, posted on Dec 03, 2007
I own an Epson stylus C82 and have just replaced the cartridges, yet it still wont print certain colours. I have cleaned the cartridge heads and taken all the steps that Epson suggest, but still have no result. It only seems to want to print magenta. Please help
Comment by Melanierc, posted on Nov 25, 2007
I have put in a new black toner - the coloured ones are low but not out. The printer will not print - comes up with an error message. WOn't print a test page. Have uninstaloled and reinstalled software but no joy. whero@clear.net.nz
Comment by Guest, posted on Nov 18, 2007
I have just inseted new HP 78 cartraidge but it does pint out in colour as if empty
Comment by Josu, posted on Nov 09, 2007
When I had put the new ink it didn' t want to print the words in Microsoft Office Word 2003.
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Van Nuys, CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
