Question about GE WBSR3140DW Top Load Washer
Machine will not spin water out of cloths.
I installed a new trans and clutch and now the machine will not spin all the water out of the cloths.
  • ladybirgy Feb 09, 2009
    Washer drains but will not spin out You have to give it a spin by hand to get it going.
  • Anonymous Mar 20, 2009
    will not spin
    Scholar:
  • 42 Answers
A tranny or clutch problem is typically associated with a complaint of "the washer will not spin"
If you're complaint is now "washer will not drain" (you can see water at bottom of tub at end of cycle); I would check and test the water pump and ensure your drain-line is clear (machine & house-line). Note: You can double-check by having your washer drain into a bucket or something (outside).
You may have a defective pump / pump impeller which will not give the amount of pressure needed to drain completely (broken blade or something).
What was your original problem? Who advised it was the tranny/clutch? Does your washer have a belt?
Posted on Jan 27, 2009
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
I have a GE washing machine that will only go into the spin cycle with no cloths in the tube, but still agitates for washing cloths. Before it got to this point I would hear a grinding sound when in spin...
these machines use the belt as a clutch and a cam to release the break the growling noise was probably the bearing going at the bottom of the trans and is now seized you may also find a water leak at the tub seal this is the most common reason for these failures you will probably end up replacing thee trans and seal kit.
Mar 08, 2011 | GE Washing Machines
Model FAV6800AWW will not pump water out if clothes are in machine but if I take out clothes, the water pump comes on and the machine pumps out water and spins. Codes DC and UC come on when it it is time...
I’m an owner of the machine and know it quite well. If the One-Way roller clutches in the clutch pulley hub and the upper roller clutch assembly (if your series use’s it) can be cleaned up and re-lubed you can be back in service today. See this post Clutch Fix. My roller clutches failed at the 3.5yr mark Dec 08 causing dc/UC errors for any size load. I cleaned up and re-lubed and it worked fine. I replaced the clutch to try this clutch assembly back in Feb 08 25001169 to see if it would work it does and I recommend it to all owners for your and mine FAV6800AW and the LCD flavor of this machine the FAV9800AW. The clutch will work for all series of those machines. If you have basic mechanical skills and want to save money try to clean up the roller clutches and re-lube or replace for $60. If you call in a repair service I think you will be in the $300 range to repair. I have changed my nickname from dh1200s to FAV9800AWDIY I have many postings on the clutch subject at this site and Fixitnow.com where my Clutch Fix posting has been posted for these machines.
Good Luck and post back if you need help to DIY. …. Rich
Oct 25, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My clothes will not spin to wring out the water
Clutch is bad, Control Panel Bad, or Motor Control Board bad. Usually the clutch you can get a new clutch online fron an appliance parts dealer there are several so shop around. INSIDE THE BACK COVER IS THE OWNERS MANUAL remove a few screws and get it. This will help aid you in self repair of MAYTAG :( I finally gave up and bought an old standard machine and I have no worries or problems with my washing machine, no stinky drum or clothes, no break downs, and no half washes. I ll never buy another high end washer set again, never.
Oct 13, 2009 | Washing Machines
Hello domino14
Your experiencing symptoms of clutch malfunction with the FAV6800AW. Do you want to dive in and try to fix? Here is what is involved to pull the clutch out of your machine. Also read the last couple of post in this forum. If you call a repair service in your are looking at $300 +. If you can DIY the repair cost could be from $10 dollars if you just need a roller clutch clean up and re-lube to $50 -140 for a replacement clutch. I’m cheap and would go for the $50 Clutch.
First check is to lift lid and see if you can rotate the empty wash basket CCW with one finger. That will let us know if you are experiencing some drag with the roller clutches in the clutch assembly. Here is a step by step to remove the clutch. It is a tight work area but can be done with basic hand tools and basic mechanical skill sets.
What is the serial number of your machine? Just need the first two digits i.e. 10, 12, 14, 16. This info is located on the top right back side of the console.
Next comment will be the clutch removal process, this board has message limits.
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Clothes still too wet after spin
Sounds like the trans has leaked oil onto the clutch. Lean machine back and look at inside of cabinet about 8 inches up. If you see oil spatter, then you need a transmition and clutch. It's usually cheaper to buy a new one.
Apr 23, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 23012 / Clothes still wet after spin cycle
Remove end caps from console (put fingers behind top and pull towards you. small flat head may be required). and the 2 phillips screws behind them. Pull console towards you and up, it wil flip out of the way. Unplug door switch connection on top rear right of cabinet (3 wires). Put flat head STRAIT DOWN into brass looking clips and push forward. They'll pop out. Lean cabinet towards you and shine flashlight inside. Look for oil splatter about 8" up from bottom. If there's oil, then the trans has leaked oil into the clutch and it's slipping. Repl. transmition and clutch assy. If you see oil, it's cheaper to buy new washer. Trans and labor is about 400
Mar 17, 2009 | Kenmore 23012 Top Load Washer
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
GE washing machine model #WBSR1060TAWW won't spin
The clutch assembly may be slipping. Mine had the same symptons and eventually the bottom part of the pully on the clutch assembly spun off. Replaced assembly and worked fine again.
Sep 21, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
