Question about Numark TT1650 Turntable
I brought a set of second hand numark tt1650 and when you turn them on and get them spinning there is a small popping/clickng from underneith what could be wrong and is it serious
  • 4,234 Answers
The unit should not be making any sounds like that. It sounds like the timing is off for the gearing underneath the platter. It may be as simple as cleaning the existing grease on the mechanism and re-lubing. The existing grease may have gummed up a bit not allowing the parts to move freely.
Dan
Posted on Jan 27, 2009
How do i hook a numark tt 1625 turntable to a regular home stereo amplifier...does the ground need to go into anything specific?
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
Feb 26, 2011 | Numark TT1650 Turntable
My numark TT500 turntable doesn't spin when i press play
Sounds to me like the belt has snapped or slipped off. Lift the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Jan 04, 2011 | Numark TT500 Turntable
How do I get my sound from my Numark TT1625 to play through my DVD/CD speakers?
You need a magnetic cartridge preamp. You then plug your turntable into it and the box into the CD/aux imput of your amp.
May 21, 2010 | Numark TT1650 Turntable
Hi there! i just bought a numark tt1650 and an ortofon arkiv cartridge, connected it properly to my old technics a700mk2 amplifier (phono, grounding and all that) but it still has a buzzing problem...
Try connecting the turntable to one of the other inputs like CD / tuner etc and see if the buzzing disappears. if so then your turntable has a built-in pre-amp so it can be connected to any input except 'phono' as this would obviously be used for turntables without a pre-amp.
a lot of modern turntables now have built-in pre-amps to compensate for certain amps and receivers made without a phono input and can now be connected just like a CD player, tuner etc.
hope this helps.
May 05, 2010 | Numark TT1650 Turntable
Tone Arm acting as arial
A metal tone arm has a ground wire that connects it to the back of the stereo via the Turntable chassis. If this wire is broken (inside the deck of the turntable) or the ground to the stereo is not done, you can have this issue. No, the ground through the audio connectors is not sufficient.
Mar 20, 2010 | Numark TT1650 Turntable
Hi,i need a mains transformer tt1650 Ron,Cheltenham,England.
that turntable wasnt made in the usa . your best bet is to google the same info.
ask where to buy that transformer etc. good luck
Aug 15, 2009 | Numark TT1650 Turntable
Second hand decks
The unit should not be making any sounds like that. It sounds like the timing is off for the gearing underneath the platter. It may be as simple as cleaning the existing grease on the mechanism and re-lubing. The existing grease may have gummed up a bit not allowing the parts to move freely. Take of the bottom and look at the condition of the grease.
Dan
Jan 27, 2009 | Numark TT1650 Turntable
Numark TT1650 Turntable Logo
186 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
