Question about Bose FreeStyle TV Speakers
Interface module module not working
  • atv10
    atv10 Jan 23, 2013
    interface module on freestyle system not working i need to try and find a source to buy one
Does the S5700 Interface Support 100M Optical Modules?
Fixed optical interfaces on the S5700EI, S5700SI, S5710LI, and S5700HI support 100M optical modules, while interfaces on extended front cards do not support 100M optical modules.
In the S5700LI series, only the S5700-28X-LI-24S-AC, S5701-28X-LI-24S-AC, S5700-52XLI- 48CS-AC, and S5700-28X-LI-24S-DC support 100M optical modules on their GE interfaces.
The S5710EI series switches support 100M optical modules only on their combo interfaces.
When a GE optical interface of the S5700 works at 1000 Mbit/s, it can only use a 1000M optical module. When the interface works at 100 Mbit/s, it can use either a 100M optical module or a 1000M optical module.
Hope can help you!
S5700 28C PWR SI Price Buy Huawei S5700 28C PWR switch Huanetwork com
Jun 04, 2014 | Computers & Internet
Location of instrument interface module 1999 cougar
pcm shows speed but not cluster ? instrument interface module ??
Feb 24, 2012 | 1999 Mercury Cougar
Promaster ftd 5700
Hello, You will need to get the correct interface module. You need the module that works with Canon digital cameras with E-TTL II which includes the Digital Rebel XT. I bought the flash and the interface module at Wolf Camera's going out of business sale and had to go through three interfaces to get the correct one for my XT.
Jan 10, 2012 | Quantaray QTB-9500A TTL Flash
CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Jul 04, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Viper 690XV Installing with INT-SL Data interface module
The number 2 pin on my cars OBD II is the data carrier which is then connected to the purple wire of the INT-SL Data Interface Module.
Data Interface Modules are becoming the standard for alarms and remote starter installations. These modules will make installations 75% faster and more accurate. I also recommend using Posi Taps to tap into your OBD II.
This a safe and 100% effective reversible method of connecting wires without crimping, cutting, or soldering. If you have any questions feel free to drop me a line or simply Google: "Posi Taps" by posi products. For Interface modules Google: "INT-SL". Good luck with your next installation. And remember the has endless resources providing you take time out to research them.
By the way my Viper install was a sucess.
Best regards,
Rico
Sep 06, 2009 | Viper Security and Remote Start System...
Same problem. Bose CineMate light went red and doesn't come back green even if I tried changing batteries and doing 5 step approach mentioned above.
If resetting this system and re-seating the interface (box with light) to the bass module doesn't fix this, you may need a new interface module. This sells for about $40-50 from Bose. If this is under it's 1-yr warranty, they should be able to replace this for free.
So just incase you haven't tried it: 1. Unplug the power cord from the bass module (sub-woofer) along with the interface module and wait at least 30+ seconds. 2. Re-connect the interface first- screw it in as tight as can be. 3. Re-connect the power cord, and try the remote again.
This is really the only solution, and it's exactly what their tech support will have you try. That's the one functionally weak point with that system, that little module needs to be adjusted and re-seated from time to time.
Jun 15, 2009 | Bose Cinemate Digital Home Theater System...
Interface module and/or bass module power problem
Eric,
Take their offer Bose is not that forgiving.
Send it back let them deal with it.
If you try to DIY it you'll void warrenty and will be totally SOL
Good luck
May 12, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Home Theater
Hello everyone! The Bose interface module is working again. All I did was unplug the power, wait about a minute and then plugged it back in. Whatever it did, it must have reset itself, so now everything is fine.
Nov 18, 2007 | Bose Cinemate Digital Home Theater System...
Bose FreeStyle TV Speakers Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
