Question about Maytag Dishwashers
Reset control panel on Maytag MDBTT60Aww
At the end of the cycle the "Clean" light does not come on
gwshaw71
  • 83 Answers
SOURCE: maytag dishwasher MDBTT60AWW
if you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Posted on Nov 25, 2007
SOURCE: Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
Posted on Jan 16, 2008
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
  • 25 Answers
SOURCE: Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Posted on Jan 23, 2009
  • 1382 Answers
SOURCE: Reset control panel
If the clean light blinks 7 times and pauses,you have a problem within heat circuit,inspect the element for cracks or breaks.The actual door latch could be out of alignment also find the latch and bend it downward ever so slightly to assure good connection at door switches. To clear code push hitemp-airdry-hitemp-airdry,this will allow you to run cycle if code comes back,you may need servicer.
Posted on Apr 03, 2010
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
My dog locked the control panel on my epic maytag washer
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Service Manual
Apr 04, 2011 | Maytag Washing Machines
CONTROL PANEL LOCKED LIGHT ON, WASHER WONT WORK.TRIED UNPLUGGING TO RESET.
Press END OF CYCLE button and hold it for 10 seconds.. It will turn of the control lock feature..
Oct 06, 2010 | Maytag EPIC MFW9700S Front Load Washer
Regarding Maytag Dishwasher, model # mdb4651aww3. Most of the lights on the control panel will not light up. You can't change cycles or set the delay timer etc. You can hit the start button and it runs a...
I have same problem with my Maytag. Had a repair guy come out and he said it's the 'controller card', not the button touchpanel. The controller card is $127 and not in stock and there's a 'several month wait'. I'm not going to wait, going to buy something used for less than the price of a new controller card. Maytag's quality has really deteriorated in the past few years. They used to have a 5yr warranty on pretty much everything - now it's only 1yr. (and of course, mine failed just a few weeks after the 1 yr time.
Jul 25, 2010 | Maytag 24 in. MDB4651A Built-in Dishwasher
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Jan 09, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwashers Logo
69 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
