Question about Zebra 105Se Thermal Printer
Zebra 105se label length is wrong
I've performed several Calibrations, set rest position, set tear off position, etc.... No matter what I've tried, the length stays at 1225. I need it to be at 1252. What can I do to fix this?
  • CL69 Apr 01, 2009
    My printer was set and all of a sudden stopped calibrating properly. I shut it down, and chaged labels... no matter what, it wont recognize the new labels now... what should i do?
  • 155 Answers
But physically measuring the label 1252? You can also disable the calibration options and then use the command ^XA^ LL1252^XZ. Also try to download the latest firmware for your printer.
Posted on Mar 10, 2009
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
Jun 04, 2014 | Zebra 105Se Thermal Printer
I am using a Zebra 105SE printer. When I print labels, I can not get the text to start at the top of the label. No matter what I do, the text starts half way down the label.
Label position may be off. Power on while pressing the cancel key for 10 seconds. This should print a configuration label. Use large label for this. Check the parameters, specifically top position and tear off position. The default is 0. You might also check the main drive belt for stretch or missing teeth. You need a user manual for that printer because there is no lcd panel. It is not user friendly without manual.
Nov 11, 2010 | Zebra 105Se Thermal Printer
On Zebra 105Se printers, what is the a command line to allow label length calibration (2-3 labels used), but not sensor sensitivity adjustment (which wastes so many more labels). I know it exists, as...
The line is part of the ZPL (Zebra programing Language) set and can be downloaded at http://www.lancerlabels.co.uk/zplcommands.pdf
The command you want is on page 187.
Jan 14, 2010 | Zebra 105SL Thermal Label Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Zebra 105 se label length is wrong
But physically measuring the label 1252? You can also disable the calibration options and then use the command ^XA^LL1252^XZ.
Jan 27, 2009 | Zebra 105Se Thermal Printer
Zebra 105SE configuration settings
Please scroll the printer parameter untill you fine LEFT POSITION parameter and adjust as you needed.
Nov 03, 2008 | Zebra 105Se Thermal Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
How to access the settings to change the top of form or tear off position
Press the front panel MODEswitch until the POSITION LED is on, then press the UP or DOWN arrow until the label perf is positioned at the tear bar's edge. Press the MODE switch again until the printer reboots.
Feb 03, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
549 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
