Question about LG XBR446 DVD Recorder/VCR
LG VCR GC480W can't tune in to tv
I had a Panasonic VCR, tuned through a set top to channel 0 on my LCD TV. I connected my LG VCR up in the same way, but I can't get it to tune in. I am keeping the set top for the hard drive.
Please help. Philip
  • philip682 Jan 30, 2009
    Thanks for trying to fix my problem, it wasn't enough. I have since had my vcr tuned in by a profesional, and I might add LG isn't easy for anybody without the know how.
    Thanks again Philip.
  • skitss Feb 15, 2009
    I have exactly the same problem. Any details on how you fixed it?
    Problem Solver:
  • 3 Answers
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Posted on Jan 27, 2009
VCR Recording OK but cant see tape content
VCR may not be tuned to the right channel. If you are using your VCR for the tuner then your tv is set to channel 3. Check your cabling again as well. From the wall to the VCR. From the VCR to the TV. You also need to make sure that you programmed the VCR for all of the channels. Just like you would for a TV.
Jan 20, 2013 | Panasonic Nv-Vp32 Dvd Vcr Combo 110-220...
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
I want to set up my video recorder to my tv and have forgotten how to do it. I have connected the two by aeriel but cannot see what else to do.
Youe aerial should be in the rear of the VCR & the other cable (flylead) should come from the output connection of the VCR & into the TV. To easily find the VCR channel insert a film tape into the video & press play, now selecting the VCR channel on the TV (EG. channel number 0) now you will need to go into the manual tuning on the TV & search until it finds the playback film, once this happens, store this setting. An easier alternative would be to buy a scart connector & connect this from the VCR to the TV & then the video channel will show on the AV setting on the TV, this saves you any tuning problem.
Oct 14, 2009 | Daewoo Televison & Video
LG VHS GC480W How do I tune the VCR to the TV
Here's the manual:
http://au.lgservice.com/jsp/common/ManualViewer.jsp?DOC_ID=KROWM000094372&FILE_NAME=KROWM000094372.djvu&ORIGINAL_NAME_b1_a1=GC990W1F.NA2ALL_29U.djvu&FILE_GUBUN=I&BUYER_CODE=AU000001&COUNTRY_CODE=AUS&DJVU_FLAG=Y
You need the Djvu reader, to view the manual:
http://www.celartem.com/en/download/djvu.asp
Jul 25, 2009 | LG XBR446 DVD Recorder/VCR
I NEED TO KNOW HOW TO HOOK THE VCR UP TO THE TV SET. i LOST MY MANUAL I have PV-V4521
If you are using an antenna put your antenna connector into the rear of the VCR & then using a connecting cable (RF flylead), take this fron the other socket at the rear of the VCR & connect this to the antenna connector on the TV, you will then have to tune the TV to the VCR. Select channel zero for example on the TV, insert & play a tape, & then tune the TV in until it picks up the video playback picture then store this channel on the TV settings. Alternatly, do as above only use a Scart cable & connect this from the rear of the VCR to the AV connection on the rear of the TV, then when you wish to use the VCR channel, select the AV option on the TV.
Jul 11, 2009 | Panasonic Televison & Video
I inherited an old Sony Trinatron TV it's working fine & have just bought and LG VCR to replace a VCR that broke which also works fine. The problem is in tuning the VCR into TV. I automatically tuned...
Depending on where you live you might have to go buy an HD antenna and scan for channels and hope you can get a PBS station or something to get you off of zero and then go into the menu and manually program a channel you can use to tune your VCR maybe that might do the trick
Jun 22, 2017 | Televison & Video
Tuning VCR into Tv
Set the LCD to TV source and tune the LCD TV channel to 3 or 4.
For best viewing experience, you should connect the LCD TV to the VCR using component / SVideo or RCA cables instead of RF coxial to avoid signal loss. Your VCR manual should indicate these types of connections.
Aug 11, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Tv problems
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Mar 04, 2008 | Konka K1938U 19" TV
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Programming panasonic vcr
First, check in the VCR setup and see if it set for cable or off-air/broadcast/antenna (not always named the same).  If it is set for off-air... then it won't tune cable channels beyond 13.  It must be set for cable mode in order to tune those upper channels (mid-band, superband etc.).
I assume you have the VCR hooked up correctly- cable into VCR antenna/RF input, VCR RF/to TV output to the RF/Ant input of the TV.
Oct 15, 2007 | Panasonic AG-1980 S-VHS VCR
LG XBR446 DVD Recorder/VCR Logo
273 people viewed this question
Computer Repairing
Computer Repairing
