Question about Hotpoint Washing Machines
Belt keeps coming off hotpoint wml730 washing machine
  • 1294 Answers
SOURCE: belt fitting for a WF000 hotpoint washer?
It should go around 2 wheels; one is the pulley of the motor, where there is a good groove. The other goes around the tub wheel which is big one. First fit to the motor wheel then fit to one side of this big wheel & turn the wheel to engage it gently. The belt should have a "give" of only half an inch, or it will be too loose or too tight.
If helped pl rate.........
Posted on Dec 28, 2007
gittos73
  • 244 Answers
SOURCE: hotpoint washing machine belt come off
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Posted on Jan 27, 2008
barkencoa
  • 3463 Answers
To refit belt, remove top cover and rear lower panel at bottom of washer.
Tilt the m/c towards you.,you may need assistance to hold m/c.
Put the belt round the motor pulley first, and then fit it on drum pulley, slowly turn the pulley feeding the belt round as you go, it will be very tight, so be careful not to trap fingers., just keep going until belt is on, there is no adjustment needed as belt is self tensioning.
The belt needs to sit in the middle of the pulley.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
  • 100 Answers
SOURCE: hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Posted on Jan 27, 2009
  • 56 Answers
SOURCE: fitting new belt on hotpoint washing machine
check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
Posted on May 15, 2009
Hotpoint aquarius wml730 will not start program, machine is full of water. How can i force start it?
It's more than likely the pump at the base of the washer . Easily solved if it is . Follow these steps .1 take the machine near to a outside door and make sure the front is over the edge . 2 at the base if the washer there will be a panel you can either remove or drop down . More on next post 11_21_2013_2_04_46_pm.png
Oct 16, 2013 | Washing Machines
The belt on my hotpoint aquarious wma33 keeps coming off
Belt is not adjusted tight enough when being fitted, if no adjustment can be made by moving the motor then the belt may be stretched and will need replacing, the drum bearings may be faulty and causing the pulley to be out of alignment, water may be getting on to belt causing it to slip off.
Dec 29, 2012 | Hotpoint Washing Machines
Drive belt on hotpoint wm56 keeps coming off when machine goes on fast spin. I have fitted a new belt but it still keeps happening.
Make sure belt is reasonably tight, and it is in the center of the drum pulley, if it still comes off, then I would suspect that the drum bearings are worn, or the drum is running out of alighnment, or the motor bearings are worn, if it is noisy when you spin the drum by hand, then the bearings have definately failed.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WM56 Front Load Washer
Hotpoint washing machine belt come off
Thanks.
Jan 10, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Give me a good rating before you sign off! I just gave you info that's GOLD!! About PUSH-PULL!
Sep 05, 2008 | Washing Machines
Dec 29, 2007 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
42 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
