Question about Seagate Momentus 4200.2 (ST9808210A) 80 GB Hard Drive
How to transfer data from a removed seagate momentus 4200.2 to another computer
5 Suggested Answers
  • 9 Answers
SOURCE: Seagate Momentus 4200.2 120GB
Some laptop manufacturers use the 4 pins to the side of the data connection to force Master / Slave. Do you have a jumper shorting 2 of these pins? If so, remove the jumper and try it again in your external caddy. Had this problem 2 weeks ago with a Toshiba notebook having the Blue Screen of Death. Removed the jumper and then the disk worked perfectly!! Strange but True.
Cheers
Tim
Posted on Dec 13, 2007
MrDallasIT
  • 91 Answers
SOURCE: I don't have an instruction manual for my Seagate 160 GB External
Well, if it is a USB Drive, you can locate the drive on your Computer. and using Windows explorer would be a lot easier, click on start, all programs, accessories, Then click Windows explorer, and on the left hand panel, you can then search your drives and located the data that you want to copy and paste. For example, I am going to copy my documents from my (C:) drive, and I then will paste onto my USB flash Disk Drive (J:)..you will see the files go from (C:) to (J:) drive once you start the process...thats it!
Posted on May 19, 2009
  • 27 Answers
SOURCE: how do I transfer data from my hard drive to added external drive
you can this many different ways. The most straightforward is to go to the drive and select "folder and file options" in the view menu and selct "show hidden files", that way when you copy and paste you will get every single file. The other way is to use a program such as Acronis Tru Image and use the clone option. I am assuming that you want an image of your C:\ drive.
Posted on Sep 14, 2009
bronk50
  • 27725 Answers
SOURCE: clicking Seagate Momentus 5400.4 200GB
if its not recognising your hard drive you should not be getting a screen?
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work but if it is
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also check the Cmos battery and computer ram make sure they are securely seated
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system information all of your computers information will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Posted on Aug 01, 2011
FreeAgent Pro USB broken -- need data from Momentus drive
Momentus is a SATA drive, so you can put it in any PC that has SATA bus to access the drive.
If you can borrow a SATA to USB dock, you can put it in the dock and plug the dock to USB port on a computer to get your data out the drive.
One example for the USB dock is EZ-dock and you can search on Internet for the picture.
Apr 11, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Seagate Momentus 5400.6 500GB hard disk is told to be inaceesible and corrrupted by my pc. the plug of hard disk was broken so i changed the casing twice , it works finely for 2 3 days and then there...
Internal hard drives should only be opened in a clean room. If I understand you correctly this drive is bound to fail. Suggestion: Start moving files onto other space.
Aug 28, 2012 | Seagate Momentus 5400.6 500GB SATA/300...
Seagate Momentus 5400.6 500GB ST9500325AS external drive, when plugged in, starts beeping for a short while then Windows 7 detects it, but can't initialize it in the Disk Management screen. I do not...
If you try to initialize it, you will destroy your data.
Try another PC or better still a Mac. You may be able to read it but it should spin up otherwise it could be the usb connector.
Aug 06, 2017 | Seagate Momentus 5400.6 (ST9250315AS) 250...
Seagate Momentus 500GB hard drive on a Dell Latitude laptop running Windows XP with an Excel spreadsheet open. I went away for about 20 minutes, came back and unlocked the user and then blue screen with...
This is a typical hard drive failure scenario, please check if your computer has valid contract if so get your hard drive replaced.
If you have valuable data in your hard drive and willing to spend you can go for hard driver data recovery which is an expensive process.
Jan 04, 2011 | Seagate Momentus 5400.3 Hard Drive
My seagate momentus 5400.2 external hard disk can't be detected by any computer. doesnt show up in the device manager, or anything. the light is on, for some reason, sometimes it blinks red/green,...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Seagate Momentus 4200.2 (ST9808210A) 80 GB Hard Drive Logo
14 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
