Question about Zebra 105Se Thermal Printer
Zebra 105 se label length is wrong
The lable length on the configuration is wrong. It reads 1225 and I need it to be 1252. I've performed the calibration, set the rest position, and set the tear off position. No matter what I've tried, the label length is set to 1225. How can I change this?
  • Anonymous Feb 05, 2009
    Zebra 105 se label length is wrong problem, and notify you when a new solution is offered.
  • 155 Answers
But physically measuring the label 1252? You can also disable the calibration options and then use the command ^XA^LL1252^XZ.
Posted on Mar 10, 2009
In my application,i want to print the barcode generated from the application.i am using TTP 244 plus printer for printing the generated Barcode.but printer skips two lables and print the generated bar
Please verify the following:
- Driver: If you are using the standard printer driver, maybe you want to try another driver(Download an excellent driver at www.nicelabel.cl, searching by your brand and model name).
When installed, you should go to advanced settings and use the callibrate options.
- Software: Maybe your software has a configuration and the driver has another, set the same length for both and verify if the problem persists.
- Sensor: If the sensor has an issue, then you should try contacting a local reseller or partner for zebra. If that's the case, you probably will have to repair the printer($) or definitively replace it for another($$). Since it's a desktop printer, check your warranty first and maybe you are covered.
Jan 16, 2015 | Zebra GK420t thermal transfer and thermal...
Zebra s600 prints on label and feeds 3 blanks
it must be wrong label configuration or problem with gap sensor.
You can follow this step by step zebra designer ;
Zebra Designer Kurulumu ve Kullanm Teknik Barkod Etiket
Jul 02, 2014 | Zebra Stripe S600 Thermal Label Printer
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
Can we make 300 dpi Zebra 105 SL printer to print on label expecting 203 DPI, Any configuration setting?
Krishan, sorry there are no settings that will allow you to do this on the 105SL. If the printer code expecting a 203 DPI printhead and you have a 300 DPI Printer then your label will print out much smaller then normal.
If you are printing labels with a label printing package (such as Seagull Bartender for Windows) then all you need to do is to install the proper printer driver. If you have your printer attached to a system that is sending "straight" ZPL (Zebra Printing Language Code) then your out of luck.
Hope this helps
Mikeo@acebarcode.com
Feb 28, 2011 | Zebra 105SL Thermal Label Printer
Only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra 105se label length is wrong
But physically measuring the label 1252? You can also disable the calibration options and then use the command ^XA^ LL1252^XZ. Also try to download the latest firmware for your printer.
Jan 27, 2009 | Zebra 105Se Thermal Printer
I have a Zebra 160s lable printer & i want its installation S\W
You can use software such as Label Matrix, BarTender, EasyLabel or ZebraDesigner (free on zebra.com).
Jan 17, 2009 | Zebra Z4Mplus Label Printer
Configure labels
you must set the software to 3 accross
Nov 07, 2008 | Zebra TLP 3842 Thermal Label Printer
Printing mixup
Your problem is a computer configuration issue, not a printer problem.
Without knowing any details of your system configuration, it is impossible to offer and further advice.
Steve W
LazerTek, LLC
Jul 02, 2008 | Zebra 140XiIII Plus Thermal Label Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
430 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
