Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Lid switch won't click
When I close the lid, the switch won't click. If I stick my hand under it and hold something (because I can't see what I'm actually holding) and push on the gray piece, it clicks. Sounds like something is loosse/broken. It is a Whirlpool Ultimate Care II washer. How can I get access to the switch to see what's actually wrong? How can I remove the top of the machine easily/without breaking anything else? Any thoughts?
Thanks!
  • Whirlpool Master
  • 909 Answers
Whirlpool has no panels. Tilt your machine backwards as far as you can so as to allow you to view the lid from underneath. there you will see a lever that makes contact with the limit switch as you open and close it. See what the problem is and rectify
Posted on Jan 28, 2009
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
Doesn't start after filling with water - model 110.15962401
check the lid switch,your lid switch is under the top console,open the lid and close it a few times you should hear a clicking sound,open the lid and stick your hands in the back above the tub,there's two clips one on each side that holds the top console down,or you can use a putty knife and stick it under the console and pop the clips,you'll see the lid switch on the left side,part number 8318084 and it's around 20 dollars.
May 09, 2011 | Kitchen Ranges
Have a kenmore elite washing machine which i purchased in 2005. The machine will stop in mid cycle and will start again when the door (top load) is opened and shut again. Could this be a problem with the...
what cycle does it happen in?close the lid and open it a few times,does it make a clicking sound,if it does i would say the switch is good,also you can do this,next time it happens open the lid carefully without banging the machine so you don't disturb anything,get a screw driver and stick it in the hole and see if it runs, if it does i'd say it's the switch,but i've seen this before right before it goes into the spin cycles,the clutch doesn't fall in the tranny. and when the lid is opened and closed the clutch falls.keep an eye on it and see where on the timer this happens,make a mark and see if it does it in the same spot,depending on how hard you close the lid it could be the switch,the timer sticking,i've tapped the timer when something like this happens and it sometimes starts or the clutch in the tranny,when you close the lid did you ever notice if you heard a clunking sound and then it starts to spin..also if you open the top console,unplug the lid switch and stick a jumper wire in the two outside holes of the part you unplug,the lid switch is closest to the right side clip and it's a white connector, you can bypass the switch to check it, all it is is a safety so the machine won't run with the lid open or instead of doing that you can stick a screw driver into the hole and let the machine run like that if you think it's the switch,let me know what you find.
Apr 19, 2011 | Washing Machines
Lid error message
THE MOST common fault of this kind is the spindry went out of ballence and tripped the safty tab at rear of the wash/spin drum under the rear of the lid. if you slide your hand under the cover rim you can pull the wash drum toward you with your left hand to give a little space to view the under side of the lid you should be able to bearly see a tab sticking down or something the drum could bump into if pushed back far enough if this is so then gently flik or pull this tab forward this is a safety cutout switch leaver, close lid and test
other problems could be a bent lid or corroded parts
Mar 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
Kenmore washer
the switch can be bypassed BUT if you do be careful it is after all a safety device to prtect those who "know no better than stick their hand in a wash tub spinning over 700 rpm" the switch may be on the left side just behind left lid hinge on some it was even under right side and others on right edge of lid opening either the screw holes are broke off or lever is not pressing in to activate switch..1 other thing ck screws in hinges if left side is loose have seen it fail to engage switch lever
Aug 07, 2008 | Washing Machines
Kenmore 70 series
It sounds like you have a bad lid switch. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
Some washers have the lid switch under the right-hand side of the wash tub opening and is activated through a small slot on the wash tub casing rim by a small plastic piece on the lid called a lid strike. If this is the type you have, make sure the lid strike is still intact or the switch will not activate. Check the two mounting screws next to the slot and make sure they are present and tight. These are the mounting screws that hold the lid switch in place. If they come loose it can prevent the switch from activating.
Newer models have the lid switch mounted under the washer casing in the left-hand rear adjacent to the left washer lid hinge. The switch is activated by a rod on the lid hinge. Sometimes a simple adjustment of this rod can correct contact problems.
No matter what configuration you have, if you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to accomplish this:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require further assistance, please let me know. I hope this helps you.
PS If you provide me with your COMPLETE model number (located under the washer lid along the tub rim) I can also assist you with locating parts.
Jul 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does not want to start spin cycle
Check your lid switch. This is a common failure with this model washer and it is a simple repair. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
If you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to replace the switch:
Let me know if you require further assistance or part sources. I hope this helps you.
Jul 03, 2008 | Whirlpool Washing Machines
Kenmore Elite Model 110 washing machine will not stope the agitate cycle
If the washer fills but does not agitate or spin, this is usually a symptom of a bad lid switch. The switch will either be located on the right hand side of the washer tub opening, or in the rear on the left hand side under the console. If you have a right hand model, examine the lid and make sure the plunger that activates the switch when it is closed is still intact. The plunger is a plastic piece that is physically mounted on the lid. Sometimes they break off. If the plunger is intact, try taking a small object (like a screwdriver or popsicle stick and push down on the lid switch contact while the lid is open and the timer knob started. You should hear a distinctive "click" when you push on the switch and the washer will agitate. Sometimes the switch can become loose and no longer make good contact. If this is the case, simply tighten the two mounting screws on the tub opening. If the switch relay is not clicking you may need to replace it. The part runs about $35.
If you have the left hand style switch that is enclosed under the console, the contacts are closed by a small metal bar on the back of the lid. Sometimes this bar becomes bent or loose. Open and close the lid and listen for a distinctive "click". If you don't hear anything, you may need to adjust the metal bar, or replace the switch. This style of switch tends to cost a bit more.
If you can provide me with your model number (located under the wash lid along the tub opening), I can research the part number for you and let you know where you can get it and give you step-by-step instructions on how to replace it. This is a simple repair job that the average consumer can perform with simple instructions and a few household tools. First, determine if this is the cause of your problem. Post back with comments and let me know if this helps you.
Nov 23, 2007 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
