Question about Arris DRC800 Remote Control
Need code for Samsung model # UN55EH6001
WENT THRU THE ADDING A TV CODE, BUT REMOTE FAILED TO WORK. TRIED TO SCAN FOR CODE, BUT STILL WILL NOT WORK.
Hi I have a RCA Model L32HD31YX12 tv and cannot find the code to set up on a universal remote.
You might try this, worked for my Comcast remotes:
Code for Comcast Remote Control is 13183
Code for Voice Control Remote Control is 12292, however when you go thru the automated process of programming your TV you need to select TCL as your TV brand. Do not select RCA for Voice Control Remotes.
Aug 17, 2015 | RCA Televison & Video
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
Need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Jun 04, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
I have Microsoft Xbox 360 Universal Media Remote and can't get the TV codes to work on my Viewsonic TV. I tried manaully scaning for a code without luck. Can any one suggest a TV code for a Viewsonic...
just to be sure go thru the steps for the remote to scan properly:
http://support.xbox.com/support/en/us/xbox360/hardware/accessories/media/universalmediaremote.aspx
If you already went thru these steps then I would suggest going to this page:
http://www.xbox.com/NR/exeres/3D295224-0688-4AFE-B6AB-0580AD69C86D.htm
It has all the codes for viewsonic tv's. If you go thru all these codes and you manually have the remote try to find a working code but to no avail, then the remote is not compatible with your TV, but there is always the last step of calling Microsoft support:
http://support.xbox.com/support/en/us/nxe/contact.aspx
If they cant help then you know for sure the remote isn't compatible with your TV.
Jan 23, 2010 | Microsoft Xbox 360 Universal Media Remote
Can't get my Phillips universal remote to program my tv controls on my sv2000 t.v/dvd combo.
If you already tried the tv codes for your make of tv, the manufacturer suggests using the dvd codes for your same tv make sometimes they use the dvd codes to activate or control the tv on some of those tv/dvd combos. If all this fails you can always use the code search procedure described in your remote's manual, but you need to be patient because this procedure will scan thru all the programmed codes(vcr,dvd,sat,cabl etc.) one at the time.
Jan 16, 2010 | Philips Universal PH301S Remote Control
Unable to exit a repeating promotional loop
Try these codes in your universal remote. One of them should work for your model.
1053
1056
1057
1059
1060
1061
1083
1004
1007
1018
1047
Jul 24, 2017 | Samsung TV Remote Control
Remote tv control
The model number you gave isn't recognized by either Samsung at their download center and remotes.com sells the remote, they also do not have a part number on the 'Original Codes' page that even resembles that part number:
http://remotes.com/remotes/servlet/rs?a=Display&contents=codes_original&uuid=12220919936470
Since codes are so model and brand specific, unless you find the user guide on line, your chances are slim. Study the remote to see if it may have a built-in scan feature that allows you to step through every available code to find one that works.
Sep 22, 2008 | Samsung Remote Control
Remote code orion tv/vcr # tvcr0950bw
I have an Orion TV/VCR combo with a Philis Universal remote. I had to use the Sansui codes for the combo. My code for my Orion was 632.
Dec 06, 2007 | Orion1934 19" TV
Arris DRC800 Remote Control Logo
60 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
