Question about Asko W6761 Front Load Washer
Door not closing
The door to my washing machine won't catch. worked just fine yesterday.
  • Asko Master
  • 909 Answers
If you dont have a problem with the catch, then either your door latch is defective or possibly a wire has burnt off or come loose from the connecting point
Posted on Jan 27, 2009
Frigidaire gallery washing machine door lock light doesn't come on
normally the door catch on washing machines have a switch attached to it ,if the door is not closed properly then the switch is not operated ,stopping the door lock light coming on
try slamming the door shut or check door catch for damage or hold /push and (hold )door shut to see if lock light comes on, if it does then the problem is door catch, adjustment or replacement only suggestions .good luck
Sep 27, 2016 | Frigidaire Washing Machines
WHY MY MAYTAG DRYER PYE2300AYW WON'T START
Test the thermal fuse on the side of the heater housing. It should read closed for continuity. If open, you will need to replace the kit. Here is a link to the kit you need.
Oct 30, 2012 | Maytag Pye2300ayw Dryer Door Switch...
Door won't lock
try pushing the door and hold in if this does not work the door catch is faulty replace internal door lock then should work (common fault)
Sep 28, 2012 | Indesit IWC6125 Front Load Washing Machine
Hi yesterday the door of the washing machine hotpoint aquarius 1000 wouldnt open. i turned it off took the top off and undid the catch with my finger. Now the door opens fine but its not getting any power....
Mike, you probably have a failed interlock...The latch which locks the door during the wash. It has an internal switch...That's why the machine wont start till the door is closed.....Most probable answer is to replace the interlock...If you want to do it yourself, you'll have to undo and refit the door seal...Or...It's not a big job for a tech...Good luck....Nomess
May 17, 2010 | Washing Machines
Door wont stay closed
Either the door catch or spring is broken, or the door lock is not working
The parts are fairly easy to fit,once you have determined what part or parts you require.
Hope this helps.
Dec 15, 2009 | Zanussi F1045W Front Load Washer
Washing machine wont start - close door message
Hi.
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Machine suddenly stopped working says the door is open when it is shut
Hiya .. Is there a metal hinge catch on the washer, where the door catch closes to? If there is.. its either loose, or the catch on the door itself is loose, which is normally made of plastic, tighten these up, see if this eleiminates your prob
Regards faggly
Mar 23, 2008 | Washing Machines
WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Dec 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Door wont lock
to test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
Sep 22, 2007 | Hotpoint WMA64 Front Load Washer
Asko W6761 Front Load Washer Logo
149 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
