Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch Dishwasher classixx blows fuse when turned on
Hi, I have inherited a Bosch dishwasher madel no sgs43a52. It is not working andwhen I switch it on it blows the RCD in the house fuse box. I cant find any repair manual or even a user manual for this machine. It is only about 4 years old and has had very light use, being in a holiday home all its life. Any ideas? Even a description of how to open it up to check the motor connections and heating element would help. Thanks for your time Thinking Hard...
  • 2 more comments
  • Duncan Brooks Jul 20, 2007
    I have just taken the top and right side panel off the machine, and find the pump has a fair amount of rust around it and the bottom of the plastic floor panel is covered with what appears to be salt crystals. It is damp/wet.
    I am wondering now if the pump is leaking. If the water is running through the pump and taking the salt from inside the dish washer with it, maybe this is the problem.
    Is this a likely cause? Can I just hose out the bottom of the machine? (I might even take it outside first...) How easy is it to replace the pump.
    Any other thoughts???
    Still Thinking Hard
  • Duncan Brooks Jul 25, 2007
    Thanks Crytech, Do I need to strip the machine in to pieces to get access to these parts? I have not removed the left hand panel yet, but that should be straight forward enough. What then tho...
    Does the softener have a tank, Is that going to come off easily?
    Thanks for your help.
    Thinking
  • Duncan Brooks Aug 07, 2007
    Thanks for that. Took it out side, turned on its side, took off hoses, un screwed, loosened, shook, pulled, pushed slipped, scratched hand, swore, jumped about a bit, pushed again, lifted, and removed plastic bongos. (cracked before i started application of common sense).
    Will be reversing the order of events when the replacement bongo's arrive.
    Strange thing, the guy at the parts place didnt recognise the tech term for the softener unit. Said they were a appliance parts store, not anything to do with MUSIC... Dont know what he's on about...
    Thanks for the advice, Got me out of a hole :-)
  • Anonymous Nov 04, 2008
    I have just inherited a Bosch dishwasher, the serial number I can glean from the top of the door is: SCS5312CB/12
    can you help, maybe a user manual
  • 51 Answers
No don't hose it out. That will only make things worse. There are a good number of reasons why it may be blowing the breaker. You will need to meter out the different parts to check for a short. My guess from you description is that the softner unit has broken / leaked and gone into the main pump. You will need to replace both if thats the case.
Posted on Jul 25, 2007
  • Ian Jul 26, 2007
    The softner unit is the plastic bongo's looking tub under the machine and the neck of one side protrudes into the bottom of the machine itself - this is where you put the salt into. The other half contains a browny / orange / yellow crystals ( we call resin) water pases through this & the calcium is removed from the water(softening), the salt (or salt water) the machine uses to clean the calcium resin crystals for the next time it fills. The softner will be held into position with a locking nut around the neck of where you put the salt in and perhabs with a bracket underneath. Just remove all hoses to the softner unit & it should come out pretty easy. Common sense with get you through this one!
    The machine is best serviced from the bottom, so lie the machine down.
    Good luck & enjoy!!!
Bosch Classix SGS43C12 dishwasher programs not working & dispenser drawer not opening
The control board on this model is know to have issues with dry solder joints, If you are handy with a soldering iron you can fix it quite easily.
Mar 04, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx sgs43a52 dishwasher suddenly stopped working, no power lights. It's as if the power was switched off. could it be the switch?.
it could either be the switch or the power to the dishwasher has been turned off such as the circuit breaker
Oct 29, 2011 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Nov 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Hi can't find the instructin manual for my
I usually find some manuals on here after entering the model. You sure that is the right model? Look on the inside by the door. Good luck
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Mar 14, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Feb 22, 2008 | Dishwashers
Check water
very possibly you have a faulty water flow switch. If a certain flowrate is not detected within a certain time, that light would come on
Feb 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx Electronic not working
could be faulty door switch check that either board may be at fault but before this hapens is there power at board if not you may have had a flood internally tripping flood switch
Dec 26, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwasher is not giving out water
Call a plumber to check your water pipe or you could twist the tap cap back and fort. Runs the dishwasher, if no water still. change FILL VALVE this is an electro-mechanical device that opens a valve to allow water to flow.
May also be called a WATER VALVE or WATER FILL VALVE.
If this does not solve the problem , you need to change the control board.
Does sugestion solve your problem? let me know.
Oct 09, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
2,374 people viewed this question
Top Bosch Dishwashers Experts
jimorris77
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
