How to enable folder options disabled by malicious command prompt code in Windows Xp ?
    President:
  • 2,110 Answers
Here's How:
  1. Click Start
  2. Click Run
  3. Type REGEDIT
  4. Click OK
    The Registry Editor will now open
  5. Browse to the following key:
    HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Note: HKCU stands for HKEY_CURRENT_USER
  6. In the right pane, look for the value: NoFolderOptions
  7. Right click NoFolderOptions and select Delete. (When prompted with "Are you sure you want to delete this value", select Yes.
  8. Now browse to the following key:
    HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Note: HKLM stands for HKEY_LOCAL_MACHINE
  9. In the right pane, look for the value: NoFolderOptions
  10. Right click NoFolderOptions and select Delete. (When prompted with "Are you sure you want to delete this value", select Yes.
  11. Close the Registry by choosing File | Exit
  12. You should now be able to access the Folder Options menu. If not, reboot into Safe Mode and repeat the steps outlined above.
Posted on Jan 27, 2009
How to get rid of windows command processor
How to disable the Windows Command Prompt Note: To follow the steps listed below, you'll need administrator rights and have access to the Microsoft Windows Group Policy editor.
Click Start, and in the Run box type: gpedit.msc and press enter.In the Group Policy window, browse to the User Configuration\Administrative Templates and highlight the System folder.In the System folder, double-click "Prevent access to the command prompt."Change the Setting to Enabled, then click Ok. When entering the command prompt, you should now receive a prompt similar to the example below.
The command prompt has been disabled by your administrator.
Press any key to continue . . .
If you want to re-enable this feature, follow the above steps. However, instead of setting the option to "Enabled", change it to the default setting of "Not configured."
Mar 15, 2015 | HP Computers & Internet
Tip
CMD Prompt here, add to folder context menu windows xp
Add the open cmd prompt to folder context menus also drives and MY Computer
Copy what's in the code area to notepad and save as cmd here. reg
CODE
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Drive\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Drive\shell\cmd\command]
@="cmd.exe /k \"cd %L\ ""
[HKEY_CLASSES_ROOT\Directory\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Directory\Shell\cmd\command]
@= "cmd.exe /k \ "cd %L\ ""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd]
@="Command Prompt"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd\command]
@="cmd.exe /k \"cd %L""
on Jan 06, 2010 | Computers & Internet
Internet options was disabled. how to reverse this and enable internet options?
Seems like the applet from Control Panel has gone missing.
Get hold of your Windows XP CD and try this in command line: expand D:\i386\inetcpl.cp_ C:\Windows\system32\inetcpl.cpl
Of course, replacing D: with whichever your driver letter maybe.
If you don't have a CD, hopefully they can still be in your DLLCACHE folder:
You should have 2 inetcpl* files in C:\windows\system32. If they are not there, see if you can copy them from C:\windows\system32\dllcache to C:\windows\system32.
Feb 22, 2011 | Microsoft Windows XP Professional for PC
I have a windows 7 ultimate, but i want to change it to windows xp service pack 2. can i change windows 7 to win xp without damaging all the data i have stored?
YES BUT FIRST YOU HAVE TO WIPE THE HARD DRIVE. YOU CANNOT "DOWNGRADE" FROM 7 TO XP...ONLY UPGRADE.
BACK UP ALL DATA FIRST
Oct 15, 2010 | Microsoft Computers & Internet
How do I get my computer out of hibernation
To disable hibernation in vista proceed as follows: 1. Click Start followed by All Programs and then Accessories
2. On the Accessories menu Right Click on the command prompt.
3. From the drop down menu, Click on the Run Administrator option
4. The Command Prompt window will now open
5. At the command prompt type: powercfg -H off
Disabling Hibernation In XP
The Hibernation feature can be somewhat of a resource hog in XP. If you don't plan to use it, you may as well disable it.
Here's how:
1. Go to Start> Settings> Control Panel.
2. Select the Power Options Icon
3. Click on the Hibernation icon
4. Uncheck Enable Hibernation
Sep 02, 2010 | Dell Inspiron 1525 Laptop
Installation error --- Error Code 2203 Please help, thanks
It's long but this should get your problem resolved and I would appreciate a Four thumbs up if it helps you ,If u have connected your printer only through the USB then leave out the last step.
Fatal Error 2203 - Windows XP
Windows Vista.
Giving permissions to C:\Program files folder may sometimes be difficult but here is the resolution.
Perform L3 uninstallation.
Delete digital imaging folder from C:\program files\hp folder.
Delete digital imaging folder from registry.
Deleting registry key below:
Registry Path - HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\Digital Imaging
On completing the above steps
Note: * Do not Restart the computer.
Click Start and type Run command in start search bar.
Right click command prompt and Run as Administrator
Type the following command
Net user administrator /active:yes
The above command will enable hidden account in Vista Operating system. Once enabled,
Once Restarted, "New user account will show up on logon screen called "Admin" and no password required."
Once logged in to Admin account
Reinstall the software.
After successful software installation, Please use the below command to disable hidden account feature
Net user administrator /active:no
1.uninstall the complete HP software, run windows clean up utility
2.under msconfig, disable MSconfig's sevices(non microsoft)
Aug 19, 2010 | Office Equipment & Supplies
My laptop was on hibernation. now it is not booting. please help
Hibernation is enabled by default in Windows Vista, and is one of the seven options (i.e. Hibernate) that appears on the Vista shutdown menu. Hibernate your Vista system will enable you to quickly restore to existing system state and intact workspace instead of start afresh, run programs and open your documents one by one again. If you do not use the hibernate feature in Vista, and want to delete hiberfil.sys and then recover the space occupied by the big hibernation storage file, the hibernation function can be turned off and disabled.
Unlike Windows XP, users cannot turn the hibernation on or off via Vista GUI interface anymore. Previously users can enable or disable hibernation via Power Options applet in Control Panel. This option no longer available in Windows Vista, which also enables Hibernate ability and creates hiberfil.sys by default. Instead, users have to rely on command line utility Powercf and Disk Cleanup Wizard to disable hibernation in Vista. Microsoft KB920730 provides details on how to disable and turn off hibernation on computer running Vista system. You must log on to Vista with user account in Administrators group to perform these action.
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
If you are prompted by User Account Control for permission, click Continue.
At the command prompt, type the following command, and then press ENTER:
powercfg.exe -h off
Type exit, and then press ENTER.
Another easier workaround for those who’re not comfortable to work with command line is to disable hibernation and hybrid sleep feature in Windows Vista is by using Disk Cleanup wizard tool, the built-in Windows disk cleaner to delete hiberfil.sys file. The hibernation file must be enabled to access the hybrid sleep feature and the hibernation feature in Windows Vista.
Click Start button, then go to All Programs -> Accessories -> System Tools, and run Disk Cleanup.
Choose which files to clean up, either My files only or Files from all users on this computer is fine.
On “Drive Selection”, select the Windows Vista boot drive to clean up. Note that you must select the drive where Vista is installed, which normally is also the boot drive (C:) as hiberfil.sys file will be located on the root folder of it.
Once Disk Cleanup finishes scanning the system, Disk Cleanup for Vista window will open.
Select and tick the check box next to the Hibernation File Cleaner.
You can select or deselect other type files to clean or preserve from the available items or options in the list provided.
Click OK button when done.
Hibernation will now be removed and disabled.
It will solve your problem.
Dec 28, 2009 | HP Compaq Presario V3000T Notebook
Tried installing XP, now I get a blue screen but I can not get past that point.I am trying to help someone and They tried installing XP while they had Windows 2000 prof. still on there. Nothing is working...
Please go into BIOS and there you will be able to look for an option sata ahci enabled please disable that option and then windows XP will be able to detect your hard drive and then install windows xp on the machine. moreover please install windows XP first and then windows vista, thats what the process says
Jul 14, 2009 | Panasonic Toughbook 48 Notebook
Enable standby and hibernation in my laptop again
You can manually re-enable the Hibernate option via command prompt using these instructions:
  1. Click the Start button.
  2. Select All Programs > Accessories
  3. Right-click on Command Prompt and select Run as administrator .
  4. At the command prompt enter
    "powercfg -h ON"
  5. Close the command prompt window.
Nov 27, 2008 | Toshiba Satellite L25-S119 Notebook
Folder option is missing and regedit disabled
u need to format ur system or can run a full system scan
Apr 19, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
