Question about AEG 24 in. Favorit 40650 Free-Standing Dishwasher
Dishwasher AEG FAV40620W stuck time delay
Hi! Once our daughter pushed the 9 hour time delay we were unable to undo that and run the machine. According to the manual we found online, if we hold down buttons #2 and #3 this will reset the dishwasher. I tried every combination of buttons but to no avail. Would you know what buttons are #2 and #3 or have a recommendation? Also, is there a way for us to turn off the drying cycle using the 5 buttons to save energy?
Thank you, Peter Smith (from Calif. living in the Czech Republic)
Thanks. I figured it out from the online manual. Hold buttons #2 and #3 (second and third button down on far left side) for 2 seconds should reset it. It took some 15 minutes however before the dishwasher reset!
Peter Smith
Posted on Jan 28, 2009
The dishwasher is displaying 5H in the time panel is there any way that could happen by pushing the wrong button and is there any way to make it go away
It would help to know the model number to determine the features of your dishwasher. The only guess I can make is that someone pushed the "delay" button and you are now set for a 5 hour delay for starting the dishwasher. Pressing the Delay button a few more times should bring it back to Zero delay.
Feb 28, 2015 | GE Dishwashers
Dishwasher restarts a new programme after finishing previous
try to reset program..... hold off button for 2 seconds or so..... until it turns completely off....
it this won't help, try to disconnect it from outlet..... wait few minutes,... connect it back to wall and try again
Jan 13, 2014 | AEG Dishwashers
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
Dishes not drying, greasy items not clean
You are alomost there. Yes these are some common issues and get resolved only by replacing the heating element.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | LG LDF6810ST Stainless Steel Built-in...
AEG Dishwasher 60820 Sensorlogic Delay timer stuck on 1Hr
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
However if the senslogic (pc board) has a program fault, the cost of this board = half the cost of a new washer ......
Apr 13, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
I like to know what is delay start option on my dishwasher?
Hi, It is so you can set the dishwasher up to run at a later time. If you set a 2 hour delay, it will wait 2 hours and startt on its own.
Please let me know if this helps you.
Vic
Jul 15, 2009 | Dishwashers
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
AEG Favorit dishwasher fault
check time delay function - press til '0' appears or repeatedly til all time delaying diodes do not light
Feb 20, 2008 | AEG 23 in. Favorit 50750Vi Built-in...
Can't set time delay.
Would your start button be stuck? check to see if there is something keeping it pressed in? if not your control star button could be shorted...let me know
Aug 23, 2007 | Kenmore 24 in. 16462 / 16464 / 16469...
Open Questions:
AEG 24 in. Favorit 40650 Free-Standing Dishwasher Logo
1,273 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
