Question about Samsung 793S 17" CRT Monitor
Hi my monitors screen becomes yellowish.all colour effected y dis
My monitor screen becomes yellow. all the colours have a yellow shade.every day this yellowish effect increases.
  • 320 Answers
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Posted on Jan 27, 2009
Why did my monitor's whites all turn yellow? Pages on my monitor are yellowed where white is. All other colors are note effected.
WHITE is a mixture of the three "primary" colours.
When one of the primary colours is not being produced, then it cannot produce white.
Also, check that the "data" cable is securely-fastened to the monitor and to the video-card.
Feb 21, 2011 | Samsung SyncMaster 245BW Monitor
Yellowish screen
On a CRT, "yellow" is a mixture of all 3 "primary" colours.
So, if you are expecting some other colour, then one of the 3 "guns" that are emitting one of the primary colours is NOT working correctly.
For less than $100, you can purchase a new, 19-inch (not 17-inch) LCD (not CRT) monitor.
This is less expensive than taking the CRT to a TV/video store for trouble-shooting and repair.
Jan 07, 2011 | Mag Innovision InnoVision 786 PF 17" CRT...
Hp w2007 why does the computer go pink everything that is green is now black
All the colours on the screen are created by "mixing" the 3 "primary" colours (red, blue, green).
Once the production of "green" ceases, anything that should be "100% green" becomes "100% black",
and every colour that indicates some percentage of "green" becomes a mixture of just RED and BLUE, i.e., various shades of PINK.
First, try the monitor on another computer (desktop or laptop). If the problem persists, it's time to replace the monitor. If the problem vanishes, it's the video-card in your computer that is not generating GREEN, or it is the "data" cable between your monitor and your computer that is not transmitting the GREEN request. So, you can try replacing the data-cable, or try replacing the video-card.
Jul 11, 2010 | Computers & Internet
Yellowish colour of the monitor
check the datad cable of monitor, if ok.then soldring may be dry ot the CRT neck
Jul 29, 2009 | Samsung 793S 17" CRT Monitor
My monitor colour has changed to yellowish
The first thing to try is to make sure the video connections both at the monitor and the PC are secure. A number of color image problems are just a loose connection. Make sure you remove the connectors and then reseat them when you do this.
Jul 28, 2009 | Samtron 76df 17" CRT Monitor
The colour depth of my monitor is more yellowish.
is better check your vga cable which attached pc to monitor or change your monitor color on setting
Jul 08, 2009 | Compaq CV 7500 17" CRT Monitor
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
Apr 23, 2009 | Canon PIXMA MX850 Multifunction Printer
CRT monitor becomes yellowish..
When any dust goes inside your monitor will get these things.......... remove it , it will work fine
Jan 12, 2009 | LG Studioworks 45 14" CRT Monitor
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Samsung 793S 17" CRT Monitor Logo
186 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
