Question about GE Profile JGP636 Gas Cooktop
How to replace an igniter in a ge profile model JGP389WEV3WW
How do I replace the jgp636 igniter switch?
How do I lite a whirlpool electric gas stove?
Dec 31, 2012 | GE Profile JGP636 Gas Cooktop
Cooktop model JPG933BEC2BB right front igniter quit working
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 12, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
My GE Gas cooktop model # JGP975EKSS is trying to ignite without any burners being turned on.
If all the burners are trying to ignite at the same time - the ignitor module is to blame.
If it is one specific burner - take a look at that individual knob.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 04, 2010 | GE Profile JGP636 Gas Cooktop
Ignition stoped working on my ge profile gas cooltop
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 17, 2010 | GE 30 in. Profile JGP933 Gas Cooktop
Profile JGP636 Gas Cooktop: my ignition for the gas cooktop is not clicking...
heatman101
May 17, 2010 | GE Profile JGP636 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Apr 21, 2009 | General Electric 36 in. Profile PP962...
GE Profile JGP636 Gas Cooktop Logo
57 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
