Question about Porter Cable 6,500 Watt Contractor Portable Generator #H650IS W
Powertrain xtreme generator ignition switch wiring
My 99 olds intrigue just won't turn over like my battery or something dead
How is the battery ? Do the headlamps shine bright ? Did you check the crank relay an the crank fuse 40amp ? one of the big one's ,maxi fuse . Under hood fuse / relay box . Check to see if voltage is coming through the transaxle range switch.
When the ignition switch is on, battery voltage is applied to one side of the crank relay in the underhood accessory wiring junction block through circuit 3, the PCM-BCM Fuse in the fuse block, and circuit 439. When the ignition switch is turned to START, voltage is fed to the powertrain control module connector C2 terminal 23 through circuit 5, the CRANK SIGNAL Fuse in the fuse block, and circuit 806 through the underhood accessory wiring junction block. Power is always provided from the CRANK MaxiFuse in the underhood accessory wiring junction block to the common side of the crank relay contacts. When the powertrain control module sees the crank signal and determines that conditions are OK for a crank, it supplies ground through circuit 625 to the crank relay. The crank relay now has both power and ground to the relay coil, causing the relay to pull in. When this happens, and the gear selector is in either PARK or NEUTRAL, the power at the relay common contact is passed through circuit 1737, the transaxle range switch and circuit 6 to the S terminal on the starter solenoid.
Passlock Theft Deterrent System
This vehicle is equipped with the Passlock theft deterrent system. This system contains a Passlock sensor. The Passlock sensor is part of the ignition lock cylinder assembly. The Body Control Module (BCM) interfaces with the Passlock sensor.
When turning the ignition switch to the START position with the proper key, the Passlock sensor generates an analog voltage signal, which is sent to the BCM. This analog voltage signal is of a specific value to the vehicle, and varies from vehicle to vehicle. When attempting to start the engine, the BCM compares a preset stored analog voltage value with the signal coming from the sensor. Because both values match, the BCM sends a fuel enable password via the Class II Serial Data Line to the Powertrain Control Module (PCM). As a result, the PCM enables the crank relay, and allows fuel delivery to the engine.
When attempting to start the engine by means other than using the proper key in the ignition switch, the Passlock sensor sends a analog voltage signal of a different value. The BCM compares the preset stored analog voltage value with the signal coming from the sensor. Because both values do not match, the BCM sends a fuel disable password via the Class II Serial Data Line to the Powertrain Control Module (PCM). As a result, the PCM disables the crank relay, and does not allow fuel delivery to the engine.
For more information regarding the Passlock theft deterrent system, refer to Theft Deterrent in Body and Accessories
This starting system is computer controlled , if you are not familiar with this I suggest you take a GM dealership or an ASE certified repair shop .
Nov 28, 2015 | Cars & Trucks
Where can I get an ignition switch for the powertrain pdg6500excs generator?
PowerTrain Elite Contractor Series 6500 Watts Recoil Portable Generator with Electric Starter you are outta luck,fabricate your own parts,they are not in business anymore,here are some comments,,,,
"This generator was built in china, but Honda sued them and is no longer in buissness.
"This is by far the worst generator I have ever seen in my life. The company must not even exist anymore because I cannot seem to get the generator to stay cranked for more than a couple of seconds. I have rebuilt the carb and flushed the gas tank and changed spark plug and just checked over everything, and still does the same thing. I was hoping to get in touch with the company that makes it and I cannot find anything on them or their products. Its like they never existed. If anyone knows any information on this company and how to get in touch with them please send me an email. patricknix2@gmail.com"
"where can i get parts"Asked on Wednesday, September 24, 2008 by jj from birmingham, al 35234 about PowerTrain Elite Contractor Series 6500 Watts Recoil Portable Generator with Electric Starter
Know the answer? Answer this question
Jul 14, 2015 | Electrical Supplies
Engine turns over but will not start
Check IG fuse 20A in the fuse box ! this fuse supply's voltage to the coil's an the warning lights .
IG Fuse
20 A powers these thing's !
A/C Compressor Control Module
A/C Switch
Accelerometer
Daytime Running Lamps (DRL) Control Module
Fuel Pump Relay
Generator
Heated Oxygen Sensor 1 (HO2S1)
Heated Oxygen Sensor 2 (HO2S2)
Ignition Coils
Instrument Cluster
Main Cruise Control Switch
Noise Suppressor Filter
Remote Control Door Lock Receiver (4-Door)
Apr 26, 2015 | 1999 Chevrolet Tracker
How to wire Low oil sensor 0064107
they usually just connect to earth and one wire to ignition switch wiring.
just like the ignition switch when operated they just short the ignition coil to earth
Apr 21, 2010 | Coleman Powermate Powermate 5000W...
I need a printable diagram for replacing an altenater on a 1994 ford mini-van. Does anyone know a website to find one for free?
Removal
  1. Disconnect battery ground cable (14301) .
  1. Remove snow/ice shield.
  1. Remove engine air cleaner intake tube (9A624) .
  1. Disconnect the generator voltage regulator wiring (14305) to the voltage regulator.
  1. Remove wiring connector bracket.
  1. Loosen the drive belt tensioner (6B209) and remove the drive belt .
  1. Remove the bolts holding the voltage regulator to the generator bracket (10A313) .
  1. Remove the voltage regulator from the generator bracket .
Installation
  1. Position the voltage regulator on the generator bracket .
  1. Install the bolts and tighten to 40-55 Nm (30-40 ft-lb).
  1. Install the drive belt over the generator pulley .
  1. Adjust the drive belt tensioner as outlined in Section 03-05 .
  1. Connect generator voltage regulator wiring to the voltage regulator. Tighten generator Battery Positive Voltage (B+) wire attaching nut to 9-12 Nm (6.5-9 ft-lb).
  1. Install wiring connector bracket.
  1. Install engine air cleaner intake tube .
  1. Install snow/ice shield. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more for powertrain control module to relearn the strategy.
  1. Connect battery ground cable .
Jul 28, 2009 | Ford Aerostar Cars & Trucks
Timing the cams and crank with a belt
  1. Note: Electronic Ignition engine timing is entirely controlled by the PCM. Electronic Ignition engine timing is NOT adjustable. Do not attempt to check base timing. You will receive false readings.
The CKP sensor is used to indicate crankshaft position and speed by sensing a missing tooth on a pulse wheel mounted to the crankshaft. The CMP sensor is used by the COP Integrated EI System to identify top dead center of compression of cylinder 1 to synchronize the firing of the individual coils.
  1. The PCM uses the CKP signal to calculate a spark target and then fires the coil pack(s) to that target shown in Figure 51. The PCM uses the CMP sensor not shown in Figure 51 on COP Integrated EI Systems to identify top dead center of compression of cylinder 1 to synchronize the firing of the individual coils.
  1. The coils and coil packs receive their signal from the PCM to fire at a calculated spark target. Each coil within the pack fires two spark plugs at the same time. The plugs are paired so that as one fires during the compression stroke the other fires during the exhaust stroke. The next time the coil is fired the situation is reversed. The COP system fires only one spark plug per coil and only on the compression stroke.
    The PCM acts as an electronic switch to ground in the coil primary circuit. When the switch is closed, battery positive voltage (B+) applied to the coil primary circuit builds a magnetic field around the primary coil. When the switch opens, the power is interrupted and the primary field collapses inducing the high voltage in the secondary coil windings and the spark plug is fired. A kickback voltage spike occurs when the primary field collapses. The PCM uses this voltage spike to generate an Ignition Diagnostic Monitor (IDM) signal. IDM communicates information by pulsewidth modulation in the PCM.
  1. The PCM processes the CKP signal and uses it to drive the tachometer as the Clean Tach Out (CTO) signal.
2.5L V6
The ignition system consists of an ignition coil, spark plug wires and spark plugs.
The crankshaft position sensor signal is the basis for ignition timing calculations. The alternating voltage signal from the crankshaft position sensor is digitized by a pulse former within the powertrain control module. This digitized signal is then used to position the closing time of the primary circuit of the ignition coil.
Ignition timing is determined by the powertrain control module in response to engine operating conditions based on stored data tables or maps. Once ignition timing has been determined, the powertrain control module interrupts the current to the primary circuit of the ignition coil thus triggering the ignition spark which is supplied to the cylinders through the spark plug wires and spark plugs.
The ignition coils are triggered by the powertrain control module in pairs (cylinders 1 and 5, cylinders 4 and 3 and cylinders 2 and 6) sending one ignition spark to the firing cylinder and one ignition spark to the corresponding cylinder on the exhaust stroke. This ensures that any unburnt fuel residues remaining in the cylinder on the exhaust stroke are re - ignited to provide cleaner exhaust emissions.
2.0L 4 cynder
The crankshaft position sensor signal is the basis for ignition timing calculations. The alternating voltage signal from the crankshaft position sensor is digitized by the powertrain control module. This digitized signal is then used to position the closing time of the primary circuit of the ignition coil.
Ignition angle is determined by the powertrain control module in response to engine operating conditions. Once ignition angle has been determined, the powertrain control module interrupts the current to the primary circuit of the ignition coil thus triggering the ignition spark which is supplied to the cylinders through the spark plug wires and spark plugs.
The ignition coils are triggered by the powertrain control module in pairs (cylinders 1 and 4 and cylinders 3 and 2) sending one ignition spark to the firing cylinder and one ignition spark to the corresponding cylinder on the exhaust stroke. This make sures that any unburnt fuel residues remaining in the cylinder on the exhaust stroke are re - ignited to provide cleaner exhaust emissions.
Integrated Electronic Ignition System The Integrated Electronic Ignition (EI) System consists of a crankshaft position (CKP) sensor, coil pack(s), connecting wiring, and PCM. The Coil On Plug (COP) Integrated EI System uses a separate coil for each spark plug and each coil is mounted directly onto the plug. The COP Integrated EI System eliminates the need for spark plug wires but does require input from the camshaft position (CMP) sensor.
Apr 05, 2009 | 1998 Ford Contour
Location of ignition control module
It does not have an ignition control module.
The electronic ignition (EI) for the 4.0L engine consists of the following components:
Crankshaft position sensor (CKP sensor) and 36 minus 1 tooth trigger wheel.
Ignition coil .
powertrain control module (PCM) .
Related wiring.
The PCM controls the firing of the coil based on the signal from the crankshaft position sensor.
The crankshaft position sensor (CKP sensor) is a variable reluctance-type sensor, triggered by a 36 minus 1 tooth trigger wheel configuration machined into the rear of the crankshaft vibration damper. The signal generated by this CKP sensor is called a CKP signal. The CKP signal provides the base timing and rpm information to the powertrain control module (PCM). Base timing is set at 10 degrees BTDC and is not adjustable.
If vehicle has no spark then turn key to on position,check engine light should come on.As you start cranking engine it should go out while cranking after about 10 secs. it should come back on(while cranking). If it come on then the PCM sees the signal,if it does not then PCM is not seeing it and this is your problem,either the CKP sensor or the wiring to it.
Mar 16, 2009 | 1997 Ford Ranger SuperCab
Service Engine soon light flashing or constant
code 1637 is a generator l circuit code code 300 is a multiple misfire code. from what you are describing i would lean towards wiring problem with alternator circuit.
The L-terminal circuit from the generator is a discrete circuit into the Powertrain Control Module (PCM) . The PCM supplies the ignition voltage to the generator lamp feed. This ignition voltage is pulled low by the generator once the ignition switch supplies ignition 1 voltage . The voltage stays low until the generator turns. When the generator is up and running, the PCM detects ignition voltage. Therefore, with no failures with the vehicles charging system, the lamp terminal circuit will go low 0 volts when the ignition switch is powered up and then goes to the ignition voltage after the engine is started.
I find it hard to believe you need a third alternator. if you do something is going on to burn them up. have them check wires might have a harness rubbed thru grounding out at times
Jan 26, 2009 | 2000 Chevrolet Silverado
1999 navigator
i know this worked with my 99 navigator 32 valve used a viper car starter.
Lincoln
Navigator
1997-2003
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
RED/LT. BLUE
IGNITION SWITCH HARNESS **
Ignition #1:
D BLUE/GREEN
Ignition #2:
GRAY/YELLOW
Ignition #3:
RED/BLACK
IGNITION SWITCH HARNESS***
Accessory:
BLACK/LT. GREEN
Brake Light:
L GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
WHITE/PINK
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
RED/YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
D GREEN/PURPLE (-)
DRIVER KICK PANEL
OEM Alarm Arm:
N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Powertrain Control Module (PCM) Located On Passenger Side Of Engine Compartment On Passenger Wheelwell. This Wire Can Also Be Found At the Firewall Harness On the Driver's Side of Vehicle. ** This Vehicle Is Equipped With Ford's PATS Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. *** Must power ign3 using a relay. Tap relay coil to ign3 connection of remote start along with bypass module. No diode isolation is required.
Aug 07, 2008 | 1999 Lincoln Navigator
Porter Cable 6,500 Watt Contractor Portable Generator #H650IS W Logo
517 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
