Question about HP iPAQ H5555 Pocket PC
IPAQ H5500 USB CONNECTION TO PC NOT WORKING
I've tried most of the suggestion on here but everytime i try to connect the Ipaq h5500 to the PC all the information i receive is no device recognized. i have activesync 4.5 on pc. Can anyone help please?
  • Nicke91 Feb 10, 2009
    I have fully resetted the device and can not connect it to my pc anymore!!
I sold it and bought the a new hw6910 and i don't have any problems with this one at all. thanks for your help all the same.
Posted on Oct 25, 2007
  • 490 Answers
Open active sync on ipaq and connect the cable with pc and ipaq. if not recognised perform a soft reset on ipaq. also check in  active  sync on pc >file> connection settings> allow usb connections is checked
Posted on Oct 20, 2007
IPAQ 1950 suddenly will not connect to PC to allow sync
Same problem, on four computers with two iPAQ 1950's. I installed ActiveSync 4.5, and all works fine now. This link will get you to AS 4.5:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-register.mspx
This SHOULD work for all PDAs, but I have only used it for the 1950.
Nov 11, 2008 | HP iPAQ rx1950 Pocket PC
Pc doesnt see ipaq h6315
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Apr 19, 2008 | HP iPAQ h6315/h6365 Pocket PC
Connection probleme:
1. connect the camera.
2. when the pc identified the camera and recommended to locate the driver, select locate and install.
3. after instalation done, restart the pc.
Jan 04, 2008 | Logitech QuickCam Messenger Web Camera
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
IPAQ H5555 connection problems
Hi, This could be due to a few issues, try these soloutions in order below: 1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again. 2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again. 3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case: a) unplug the USB cradle b) uninstall active sync c)Click start then click control pannel then click system. Then click on the hardware tab. Look for the device under USB, right click on the device and then select uninstall. d) restart the laptop e) Install active sync f) ONLY after active sync has installed you can now plug the cradle back into the usb socket. g) Now connect the ipaq, it should now detect it.
Aug 09, 2007 | HP iPAQ H5555 Pocket PC
Syncronizing
All you need is Activesync which can be obtained from this link.. http://www.microsoft.com/windowsmobile/downloads/activesync38.mspx and you need OUTLOOK installed and configured. It's important not to cradle the Ipaq until you are told to from Activesync. Try the following before you try to connect again... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
Cannot copy large files to my SD card
Yes , the Activesync connection is not reliable for large files. You really would be best to get a USB card reader, also it would be MUCH, MUCH faster.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
Charging
If it's completely dead USB probably can't do it at all. There's a voltage threshhold, and USB only puts out about half the voltage needed to get over it. USB usually won't manage when thenbattery's below 30%. Try connecting the iPaq directly to the AC adapter.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
Sync via bluetooth
Does your USB adapter provide serial port connections ? I had the same issue with an USB adapter with a dedicated-to-phone software. I changed to MSI bluetooth adapter and then made a serial port available to COM5, then connect activesync to COM5. (make sure on the ipaq you create a shortcut "activesync connection" and pair with the bluetooth adapter.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
Can't connect EM500 to my laptop computer
It sounds like you are using two different types of USB connections, one for the iPAQ and the other for the Casio. What operating system is running on the laptop? How many USB ports are there? You might have to reboot when you want to change from one USB connector to the other. If you have two USB ports, always connecting a USB connect to the same port (iPAQ #1, Casio #2) might help the OS keep track of what is connected to it.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
HP iPAQ H5555 Pocket PC Logo
425 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
