Question about Marantz 2230
One side not working
Right side output not working
  • 933 Answers
the 2230 is a fine unit! There could be several things causing this problem, more than likely it could be dirty front controls which will require cleaning. It could be more serious problems such as pre-amp or main amp failures, dried up output coupling cap for the right channel. I would recommend having the unit serviced. These older vintage Marantz units are really special and deserve proper attention.
Posted on Nov 21, 2016
Korg triton extreme synth. L/r outputs work fine by themselves put plug in both right side cuts out using headphone jack instead if you pull the right slightly out of input you get both sides working
I need more info to correctly troubleshoot this. However my best guess from what your telling me is that its either the Audio jack on the Korg or the headphones. If everything else is working properly replace the headphones and the Audio outputs. Post again with more details if that does not work
Jan 05, 2013 | Music
KA-994 Model Right speaker channel not working. How do I fix it?
Check the speaker of the right side first for damage. Connect it to left side and listen whether it works or not. If it works with left side, make sure that the audio output section circuit to the left side inside your amp has damaged and should be replaced. If the speker does not works with connecting it to the right side, make sure that the speaker has damaged. OK.
Dec 23, 2011 | Audio Players & Recorders
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
The left side of the output is hot and the right
switch cables of the outputs to speaker if the fault transfer to the other side you will have an internal problem and you must pass it to service center.
Jan 07, 2010 | Yamaha P3500S Amplifier
No output on the right side of the peavey 2600 amplifier but the right is ok
Each channel is protected separately. I suspect that the outputs are fried on the right side or the output fuse has blown. This should be checked by a service shop.
Jul 15, 2009 | Peavey Pv 2600 Power Amplifier
Outputs are not working
you probably burned a trace in the event and unless u have the right equipment and tools you probably wont be able to fix it
Jun 10, 2009 | Car Audio & Video
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
Hi i have an audio source 300 watt amp with a&b speaker outputs. the problem is that no sound comes from the left side outputs a or b. the right side works fine thank you mike
You have a blown channel. If you are experienced with electronics repair, use the right channel to assist in diagnosing the left. Both channels should be efectively identical. In most cases, the defective parts are the output transistors. You should be able to A/B the output amp sections.
Let me know if you need further assistance.
Jan 14, 2009 | Audio Players & Recorders
Speaker Problems
Can you swap speakers and see if the left working speaker works when plugged into the right output?
If it does, then your right speaker is bad or the right speaker cable/plug may be bad.
If the working left speaker doesn't work on the right output, then I would suspect a problem in the right channel audio amplifier.
Please let me know if I can be of further assistance to you.
- Jim
Feb 29, 2008 | Emerson MS3100 3-Disc CD Changer
No sound on right side
I think you are right. What cause this problem?
Sep 19, 2007 | Kenwood 104AR Receiver
Marantz 2230 Logo
43 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
