Maytag dishwasher E7-1195 type 776-0
Water wont drain out of the bottom of machine
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 217 Answers
SOURCE: agitator wont spin
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Posted on Nov 29, 2008
  • 35 Answers
SOURCE: Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Posted on Jun 07, 2009
beltronic205
  • 1467 Answers
SOURCE: Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Posted on Dec 16, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Neptune washing machine - wont drain & spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 22, 2010
Now it wont drain water out..indesit wla 101
Hi, If you can pull the machine out, and drop the grey outlet hose into a bucket and drain the water, once you have got all the water out, remove the filter located at the bottom right corner of the machine,by twisting anticlockwise, this is sometimes behind a plastic kick strip. clean it, and check there is nothing jamming the pump impellor.
Mar 10, 2013 | Washing Machines
I have an E39927 Type 776-0 dishwasher. The problem began this week, in that water does not fully drain from the dishwashwer following the end of any of the washing cycles. The unit seems to be...
disconnect the drain hose from under the sink. place it into a bucket and put the dishwasher to drain. if it drains in the bucket fine then you know you have a problem with your drain. if it doesnt drain, then the problem is most likely the drain pump
Oct 23, 2011 | Maytag Dishwasher
Wont drain
check to make sure it is level. top to bottom, side to side.also make sure you check the drain hose for clogs.
Aug 04, 2011 | Maytag Dishwashers
DISHWAHER WONT COMPLETELY DRAIN ALL THE WATER OUT AFTER WASH CYCLE. JUST CHANGED OUT SINK FROM DOUBLE TO SINGLE.
drain hose is to low to sink connection zip tie side connected to sink up towards bottom of cabinet top so water dosent backflush into dishwasher from sink draining
Jan 27, 2011 | Maytag EPIC MFW9700S Front Load Washer
My maytag is about 2 years old, we recently can't get the residual water after the wash to drain, so there is always water sitting in the bottom of it, it runs, cleans but wont drain all the water. what...
WEll, look for restricted screens on all pump intakes, and look for kinked drain hose. Some water MUST remain in the bottom, but usually not enough to see.
Oct 01, 2010 | Maytag Dishwashers
Maytag eq plus dishwasher- how to disassemble bottom spray arm?
its probably leaving water in it and is clogged in the elecric pum or drain hose. somethins the pump has a rubber flap that will become lodged in the outlet port. this will cause dirty water to be left in the machine because of a slow drain. start by looking at the volume of water coming into garbage disposal where drain hose hooks up.
Aug 01, 2010 | Maytag Dishwashers
Wash machine won't drain. I tried to clean a very old dirty rug and when I opened the door, it was shredded. I cleaned it out but, it wont' drain the water out.
your pump / drain in the bottom is clogged up turn the machine over after taking out all the water and then !! remove the pump and clean it and the drain hose
Jan 19, 2010 | Washing Machines
Dec 16, 2009 | Asko W600
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
Wont drain water
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 05, 2009 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
