Question about Amana Refrigerators
Amana Model#TXI21A3L Freezer not freezing
taran_2005
  • 10515 Answers
SOURCE: my amana s/s freezer will not freeze, and where
For Refrigerator or Freezer Cooling issue's, Read :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Now,
There could be many Locations, you could find the Model Number. The below link would help you :-
http://www.partselect.com/repair.aspx?appliance=model-number-locator&part=9
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 19, 2010
woodchuck789
  • 4070 Answers
SOURCE: Freezer part of my amana side by side is cold but not freezing
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 1541 on this diagram is your timer. It's under the front behind the kick panel. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=21463&diagram_id=646025#d646025
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: Amana side by side fridge - model SRD26VW freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 25, 2010
heatman101
  • 43501 Answers
SOURCE: My Amana BR22TL the freezer is not freezing - it
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 05, 2010
heatman101
  • 43501 Answers
SOURCE: My Amana Refrigerator Freezer Model
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Posted on Sep 27, 2010
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
I have an amana refrigerator model # ABD2233DES water dispenser keeps freezing up. Changed water filter laster about 3 weeks before freezing up again. pulled veggie draws out and hit lines with hair dryer...
Either the vents that are located on the lower right side are open too much or the temperature is too cold inside due to the thermostat not functioning properly.
Jun 20, 2012 | Amana ABD2233DES Bottom Freezer...
Amana bottom freezer model ABB2227DES--food in fridge is freezing when it didn't before.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Amana ABB2227DE Bottom Freezer...
My amana,( freezer on bottom) keeps freezing up. what is wrong
need model # to give you best help but freeze up is caused by no heater or terminator thermo or defrost control . now you may have a aditive defrost control this is p p c board type that controls defrost . ( a very common service ) . hope thes helped mm
Aug 11, 2010 | Amana Refrigerators
I need a diagram for amana refrigerator model sxd23ve locate defrost timer
My Amana refrigerator freezes everything. It has a bottom freezer.
Dec 02, 2009 | Amana Refrigerators
My amana freezer on the bottom has stopped making ice and the freezer isn't freezing properly even though i have it set to 7 which is the highest setting
check to see if there is frost build up on back wall .if it does u have defrost problem could be comblicated issue not knowing your expertise need make and model
Jul 08, 2009 | Amana ABB1927DE Bottom Freezer...
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Feb 08, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
