Question about Acer (90.18612.36B) Computer Speakers
Only one speaker working - acer computer speakers
Hi
I only have 1 speaker currently working, the right one which has the volume control
When I do a speaker test the left one has no sound at all. Should I just buy new speakers for my computer?
  • toddmross Apr 14, 2009
    I have the same problem. Only one speaker is working. Checked everything (balance, audio control) and everything is okay. I even bought some new speakers and the same problem persists. The new speakers allows me to plug in headphones->computer and only one side is working. If I plug in my ipod to the speakers both are working. Clearly a problem on the computer side but I just don't know. Even tried reinstalling the C-Media driver to no avail. Hardware issue inside the computer?? Help
  • Anonymous Apr 18, 2009
    speakers muted, tho have volume, in control panel and elsewhere all the way up.
  • 217 Answers
1 step: kindly check the connection of the left speaker if it is plugged to the right speaker properly.
2 step: Then check the balance under volume control if it has been set in the middle.
3 step: If possible check the speaker on some other device(cd player etc) other than your pc and see if the left speaker still doesn't have any sound.
if so kindly replace them
Posted on Jan 27, 2009
My volume is to low
Your computer should have a little speaker icon in the lower right hand corner of the screen on the taskbar. Click on it and check to make sure that volume slider is set to the maximum volume.
Also check the media player program that you are using for a seperate volume control since most players like Windows Media Player or VLC Media Player will also have their own dedicated volume control somewhere right on the media player window itself. So just make sure this second volume control is also set to maximum.
Otherwise that may simply be as much as your built in laptop speakers are able to achieve. Very few laptops will have loud high performance speakers built-in. Most people simply buy an aftermarket external powered speaker system to plug into the headphone jack of their laptop if they want / need loud high quality sound.
Here are some links to a few models of external powered computer speaker systems that are currently available on EBay:
http://www.ebay.com/itm/New-Bose-Companion-II-2-Multimedia-Computer-Speakers-System-Black-/120822567731?pt=PCA_Speakers&hash=item1c21961333
http://www.ebay.com/itm/JBL-Lansing-Computer-Compact-stereo-System-Speakers-/260815694754?pt=PCA_Speakers&hash=item3cb9d3aba2
http://www.ebay.com/itm/Logitech-LS11-2-Piece-Multimedia-Computer-Speaker-Set-/230584093965?pt=PCA_Speakers&hash=item35afe20d0d
Just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 22, 2011 | Acer Aspire 1691WLMi Notebook
Hi. I have used a used speaker recently, after using the speaker, I can not use the headset and the speaker are not working anymore, there is no option in control panel (sound) to active the laptop speaker...
I assume you have windows 7
1. Right click on the speaker icon in taskbar and select volume control options.
2. put a check mark on "All devices currently playing sound".
3. Make sure you have "The default communication device unchecked".
4. place a check mark on speakers/headphones
May 02, 2011 | Computers & Internet
The volume on my acer computer is not working but the it shows that the sound is working but i cant hear anything, can u help
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 12, 2011 | Acer 90.00012.30B Computer Speakers
Cant get computer to find speakers. keeps saying their not plugged in,but they are
you might need some drivers
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 02, 2010 | Acer (90.18612.36B) Computer Speakers
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
Right speaker not working. test show that both speakers channels working on left speaker Audio Driver updated on Acer Web Site. What is a problem?
Pls check the wires of right speaker might be some loose connection.if still issue then check in control panel and volume setting of left and right speaker
Nov 18, 2009 | Acer Aspire 4720 Notebook
Speakers not working on my acer al1714 computer screen
For no sound issues please ensure if the speakers are working fine by connecting them with a known good device other than the computer...
If they are fine then please check the connection of the speakers if they are intact (for details on connection please check the manual that came with the speakers...if its a two set of speaker the left connects to the right and the right connects to the power and  another connector goes to the line out which is green in color at the back of the computer)and if the speakers are receiving the power properly also if the volume level is set to a level that can be heard...please ensure that the audio is turned on in BIOS if the computer has and integrated soundcard....when the computer boots to the desktop check volume control to see if any of the mute option is checked if so uncheck it and also setthe volume level to high...in case the volume control doesnot open you will need to install the sound drivers...also ensure that the windows audio service is started in services you can check the same by clicking start>run>type"SERVICES.MSC">WINDOWS AUDIO if not started or disabled right click go to properties and then enable the service and click start.for the appropriate driver please specify the soundcard or if integrated then specify the motherboard details
Jan 27, 2009 | Acer AV009 Computer Speakers
Computer speakers no sound
I'm assuming Windows XP on a PC Desktop but the concepts are the same no matter what operating system.
1. Are your speakers plugged in to a power source?
2. Are they turned on?
3. Is the volume turned up on the speakers?
4. Are your speakers plugged into the (usually green) audio port on your computer? 5. Go into control panel, sounds and audio devices and check to make sure that sound is not on "mute".
5. On the Audio tab, check to make sure it shows a default sound device for each item. If not, either your sound card is malfunctioning or you need to download and install a current driver from the Acer website.
Dec 12, 2008 | Acer Aspire™ T180 PC Desktop
I have an acer laptop and i have an echoe in my sound... im not sure what the problem is. there is an internal mic i believe. help please! lol
Try right clicking on yout Volume Icon in the system tray (where your clock is). Click on Open Volume Control.
Make sure you have some audio playing, then just go through each channel and mute each one, 1 by 1 until the echo has gone.
If that don't work, then again, right click on Volume Icon in Tray, click on Adjust Audio Properties, then under speaker settings, select advance, then choose Desktop Stereo Speakers, under the Speaker Setup Options.
One of those should work. If it is your Mic causing the Echo, then you would get loads of feedback if you whack up the volume. If you don't get the feedback, then it's more then likely the Speaker Setup or some Sound FX is enabled through your Sound Card Software.
Dec 02, 2008 | Acer 90.00012.30B Computer Speakers
Acer computer speakers
Speaker issue desktop's only
1. Plug USB into USB port (any)
2. Plug Black speak cable into LIGH GREEN (NOT BLACK) connector
3. You will see a popup window - make sure it is on Front Speaker out
4. Click OK - you will a cartoon computer with speakers on either side -then click on one of the
speakers to test
5. if that does not work then follow this:
Reinstalling apps:
1. If in Windows - Start - Programs - Acer Empowering Technology - Acer E-recovery management -
click on Restore at bottom then "Reinstall apps and drivers" - look for hardware drivers that you
need. Click "install now"
Jan 06, 2008 | Acer 90.00012.30B Computer Speakers
992 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
