Question about Toshiba Estudio 200L Copier
Toshiba estudio 200: LCD problem
I can't find how to adjust the LCD contrast: it's too bright and I can barely read!!
  • vanpelt74 Jan 27, 2009
    I've found the brightness control!!! thanks anyway (yes, I was blind)
    President:
  • 2,072 Answers
I am sending this to clear it off the board. Don't feel bad, you would be amazed how many calls I have taken for Blank displays because people have hit them with their hands and trying to tell them over the phone just doesn't work.
You were persistant and found it, so good job.
Posted on Jan 27, 2009
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
How to adjust brightness
The set should have in the on screen customer menu settings for brightness, contrast, color, tint etc.
If in doubt consult the owner manual which will have instructions.
Aug 29, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Lost its brightness and clarity
Hello
Check whether the backlights get full brightness as you increase the bright ness level. Set the set to least contrast level, and check whether the backlight is sorking well. If it is OK, then try to increase the contrast level [to at least 70% of the total]. If backlight level cannot be adjusted according to the contrast level the backlight inverter baord and backlight CCFL lamps need to be checked.
images of the backlight inverter board and CCFL lamps are attached here.
Feb 21, 2012 | Toshiba 42HP66 42 in. LCD Television
Contrast is way too bright, not screen brightness, contrast. is there a contrast adjust button?
Right click on your main screen. Go to properties, or graphic properties, then you will find there is a contrast adjustment within. Usually under color correction.
Mar 24, 2011 | Toshiba Portege 4000 Notebook
Colors are off on the TV. When I try to adjust the contrast and brightness, etc from the menu, either everything is orange or green or yellow.
Contrast and brightness won't fix it.You are on the right path though.You need to search around for a color adjustment.You should have numbered scales for all 3 primary colors to adjust.It should also be somewhere under the picture option.Let me know if you need better instructions.Good luck!
Aug 05, 2010 | Toshiba 42AV500U 42 in. LCD HDTV
My laptops contrast is low how do i turn it up?
on most laptops there are function keys that will adjust the brightness and the contrast for your display. they are usually the up down left right arrows and you have to hold down FN and then press one of those corresponding keys and it will adjust the levels.
Feb 17, 2009 | Gateway FPD2275W LCD Monitor
How to adjust display contrast
For estudio E160, the contrast button is located under the panel.
[IMG]http://img.photobucket.com/albums/v260/anthonydidi2/E160Contrast.jpg[/IMG]
http://blog.diyersitzone.net
Dec 18, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
130 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
