Laserjet 5200 error 49.5001
Error message 49.5001. Tells us to turn machine off and back on again.
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: 51.20 error message on HP laserjet 4250n printer
It is an error with the laser scanner unit
1 Press ( SELECT button) to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and dc controller
PCA (J83 and J84).
4 Replace the laser/scanner assembly.
See Laser/scanner assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
If nothing from above works and the printer is no longer in warranty, it is possible if the printer is being used in a very dirty or dusty enviornment that the lens and optics of the laser/scanner are so full of debris that the beam detect error occurs. You can remove the top cover and the big black box in the center is the laser scanner assembly. Remove the screws securing the top cover of the laser scanner and remove and clean up all the optics to include the main mirror in the front. I usually use a damp q tip and for the mirror I slide up from toner cartrdige shutter area and observe from the top as it cleans the mirror. Removing the complete assembly on this model is not easy since there are a couple of cables going to the dc controller which are difficult to remove so removing the top of the assembly is easier.
Here is the service manual:
http://www.feedroller.com/Store/Service%20Manual/LaserJet%204250-4350%20(%204200-4300)%20sm.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 26, 2009
  • 2246 Answers
SOURCE: document will not print;
try tu plug off cartrij, then plug on again, turn off prin then turn on again, it may fix your problem, see
http://www.fixyourownprinter.com/forums/inkjet/26091
Posted on Jan 19, 2011
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
Hp 5200 printer error messages 49.4c18
Main board problem so u can batter replace the main board.
Jun 12, 2013 | HP LaserJet 5200 Printer
Error 49.4c18 hp laserjet 5200
hp 5200 printer error messages 49.4c18
Apr 15, 2013 | HP LaserJet 5200 Printer
49.00ff error in hp laserjet 5200
Does the same thing happen if the printer is disconnected from the network (I'm assuming that you are using an Ethernet connection) before you power-off then power-on again?
If it does, then there is a problem with the printer itself.
If not, then it may perhaps be invoked by some system sending a 'rogue' job (not necessarily a conventional print job) to the device.
Look at HP support site for the latest firmware update to your model. Regards, Mike
Sep 08, 2012 | HP LaserJet 5200 Printer
Hp laserjet 5200 the attention button red light won't stop blinking
This can be a number of reasons however I would be looking for a piece of paper jammed in the printer somewhere. Is the printer giving an error message or code?
If you turn the printer off, disconnect the printer cable, wait 5 minutes & then turn the printer back on, does it then power up & go to ready?
Apr 13, 2011 | HP LaserJet 2420 Printer
Hp laserjet 5200--fans turn on, lights don't. The computer also doesn't recognize the printer as being on.
Go to the back of the printer, look in between the large exit door and the back of the paper tray, the metal plate where your interface cable plugs in. There are 2 large screws, one on left, and one on right. These hold the Formatter board in the machine.
Turn off the printer
Undo these screws and pull out the Formatter board about 3-4 cm and then reseat it into the printer and do the screws back up.
Turn the printer back on and see if it comes to life.
If the display doesn't light up and show 'Initializing' - you might have a faulty Formatter board.
Good Luck
Dec 08, 2009 | HP LaserJet 5200 Printer
Error message 49,ff81
it is temporary printing error, turn off the machine and wait 10 sec and turn it on again it should clear.
Oct 15, 2008 | Office Equipment & Supplies
Paper jam
after you power off machine and then turn back on does machine come up to a ready state and then when you try to print it tells you there is a jam again or does the error message stay even after you power it down?
Sep 22, 2008 | HP Color LaserJet 2600n Printer
How do I fix this?
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
Good Luck!!
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
387 people viewed this question
k24674
