Question about Electrical Supplies
I have a craftsman generator model # 580.327140 it starts and runs for a minute then dies it doesn't seem to be a fuel problem
It has just had an oil change could the outomatic shut off need to be replaced
SOURCE: coleman 5500 (MZ300)
If the oil is dirty, it will not pump properly. I recently had this problem, once I changed the oil it was good to go.
Posted on Sep 02, 2008
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
protek480
  • 1714 Answers
SOURCE: The generator starts up then dies?
Check the oil pressure switch. It will shout you down like that if it doesn't sense oil pressure.
Posted on Oct 01, 2009
dmftrucker
  • 1922 Answers
SOURCE: Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Posted on Nov 05, 2009
SOURCE: Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Posted on May 18, 2010
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The engine sputter and dies after running for about 2 minutes.
I had this puzzler too! Turned out the problem is caused by the fuel-bowl needle valve. It may look OK but looks are deceiving. It gets a coating on the tip that causes a poor seal ... poor enough to allow fuel to flood the engine after a short run time. The flooded engine dies, but restarts OK after a delay that clears (cooks off) the excess fuel that flooded/killed the engine. SOLUTION: Remove the needle valve and carefully wipe and clean the tip with a white cloth soaked in solvent (gas is OK). The cloth will show the deposits that cause the problem. Carefully re-install the needle valve and float parts, start the engine, confirm that it runs OK and continuously. Simple fix .... puzzling problem.
Aug 13, 2012 | Craftsman Garden
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Generator starts than shuts down on under voltage
The problem is related to the engine. When a load is put on the generator, the engine's throttle will want to open to maintain RPMs. If your carburetor is misadjusted or gummed/varnished, when the throttle opens, you will get a fuel starvation and the engine will die. If the generator is used regularly and hasn't sat for a while, first check to make sure the spark plug is good since you don't want to make a carb. adjustment using a worn plug. After you adjust the carb. manuallly flick the throttle to ensure that the engine doesn't 'stutter' or die out. If it does, increase the gas in the air/gas mixture and if that doesn't solve it, remove, disassemble and clean the carburetor.
Jun 30, 2011 | Generac Electrical Supplies
My 7-year old 25cc Craftsman line trimmer began surging during use, would bog down when given throttle, then would completely die, became hard-starting, and now doesn't start and run at all. Acts like...
A new fuel filter with new fuel lines and a rebuild kit for the carburetor should do it. You may even be able to get away with just the gasket and diaphragm kit for the carburetor. It is cheaper than the complete rebuild kit if you choose. Run synthetic oil and these things will last a good long while.
May 14, 2011 | Craftsman 25cc Gas Line Trimmer
I have a Craftsman 2.5 Turbo 18" chainsaw. Yesterday it would start and run briefly and the die. I changed the sparkplug and cleaned the air filter and now the saw will not start. The plug is...
Seeing a lot of fuel line problems due to ethanol. Make sure your fuel lines and primer lines are in tact. If the fuel line has broken, you may also need to clean out the inlet screen in the carburetor which can also become clogged.
Feb 12, 2011 | Craftsman sears 18" Chain Saw Chain (...
Electrical Supplies Logo
130 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
